Results 1 to 4 of 4
Thread: replacing my water pump
    VE SS V8
    Jun 2009
    Default replacing my water pump
    Hi, I am going to replace my water pump this week, and I am wondering if I need to remove my intake manifold to get to the water pump.
    Thanxs Wazza
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    nah just ahve to take the air intake pipe off to gain access to it.. pretty easy job just make sure you use vaseline or rubber grease on the seal so you dont pinch it
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    I did it today, no didnt need to remove anything, theres more then enough room to get under the air intake pipe.
    - empty the coolant, theres a drain plug passenger side bottom of radiator (theres a guide on the forum somewhere on how to change coolant, follow that)
    - loosen the 4x bolts on the pulley
    - shove a 1/2" extension into the bottom of the tensioner and twist it clockwise to loosen tension on the belt (someone will have instructions on here somewhere)
    - remove the belt from the pulley
    - unbolt the bolts, remove pulley
    - unbolt the bolts holding the pump in
    - pull pump out, stand back watch for splashback
    - clean off any excess gasket/rubbish
    The seal on the Zed is a metal gasket, too easy to match up to the pump and block, even easier to put it on.
    - reverse the above steps!
    Took me half hour, is quite easy.
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Matt, u should make that a sticky!
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
  1. Replacing water pump in VS ute
    By Cobra Clutch in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-04-2009, 03:31 PM
  2. Replacing a VP water pump
    By warrickj in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-01-2009, 03:36 PM
  3. Replacing V6 water pump
    By Scooter79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-01-2009, 09:41 PM
  4. replacing water pump
    By pom89 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-11-2008, 12:49 PM
  5. replacing water pump.
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-03-2007, 09:34 PM
