Results 1 to 5 of 5
Thread: vz calais issue
    9/04 VZ Calais
    Jul 2009
    broadford
    Default vz calais issue
    hi
    im having a couple of problems with my car
    the climate control makes a flapping sound occasionally sounds like a diaphram vibrating
    only lasts a few secs then stops and ive noticed now that the a/c-heater goes onto demist no matter where the vents are pointed too for a short periods at a time( i think it sounds like a vacuum problem) has anyone had this problem before and any suggestions on how to fix it
    second
    the lh mirror isnt dipping when i put it into reverse anymore appreciate help on that too
    thanks
    rob
    VZ Calais
    Jul 2009
    with the mirror, it sounds like you need to reset it, which can be a pain in the arse - read the manual so you don't spend hours on it!!
    VY S Pac S2 & VZ V8 Calais
    Nov 2006
    With the climate control issue, sounds like one of the vacuum hoses has a hole in it or has fallen off. This happened in my vy i couldn't get the front vens to opperate and it made that flapping sound. Found out one of the vacuum hoses had fallen off, mine was the one under the headunit. It may take you some time to find out which one it is, its a pain.
    As for the mirror, it stopped working for me in my vz calais as well. Found all i had to do was press the m button of the bottom of the drivers seat while the car was in reverse to turn that feature back on.
    Hope this helps
    9/04 VZ Calais
    Jul 2009
    broadford
    thanks for the feedback
    i will try the mirror one tonite
    hose issue might be a weekender job
    vz calais 190KW A5 CHE TUNED
    Feb 2009
    SmithField NSW
    Just did the mirror thing!! omg never relise i had it!! hahaha thanx for that!!
    Cheers!!
  1. vx calais issue
    By brockee in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-09-2009, 10:06 AM
  2. VX Calais strange overheating issue
    By marsh_e79 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-01-2009, 02:33 PM
  3. VK Calais Sunroof issue
    By And_ROOS in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-05-2008, 08:54 AM
  4. VS Calais V6 Temperature Issue
    By Akshunhiro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2007, 11:07 PM
  5. VX Calais Dual Fuel Issue
    By jake_au in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-03-2006, 01:32 AM
