hey there....
im new to the whole forum thing, any help will be greatly appreciated, i've just bought a vz ss 5.7 ute...... and its shitting me already..
ive put a o.t.r cold air intake on it and its running really poor... took the intake off and the ute still is sounding lumpy.. idles a bit over 500rpm, sounds like it wants to stall and has only 1 quarter of the power, there is no leaks in the manifold and i've cleaned the throttle body... could the e.c.m be tripping out????? thanks
id say you disconnected a vacuum hose of the manifold you shouldnt have
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
checked the hose that runs from under the engine cover to the piping that runs from throttle body... seems fine.. is there any where else i should check
Check your MAF for direction and connections.
hey mate.... i know i sound like a retart but wats a m.a.f???? i honestly know very little about cars hey... thanks
MAF = Mass Air Flow Meter/Sensor
Mass flow sensor - Wikipedia, the free encyclopedia
heres some pics
http://############/jhpgto/UndertheHoo...-VZ-twin-h.jpg
http://############/jhpgto/UndertheHoo...vt-vystd-h.jpg
the sensor is the part after the airbox between the 2 silver clamps
hope this helps
If he has put an OTR CAI in then it looks like he has removed the MAF completely.
yeah air flow meter is connected right... i had to replace it today.... $250 later... i murdered the other one so it would fit on the cold air intake... "silly move"
What did you use to clean the throttle body ? have you accidentally left a TPS ( throttle position sensor ) or a vacuum hose off ? re-check all of your connections
So is the new maf connected and running in the right direction.
Most OTR CAI's don't have enough room to fit the maf between the OTR and the TB and so are designed for use with a mafless tune only which is usually done at the time of fitting the OTR because the car won't drive well with the maf disconnected but still active in the computer program.
HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
