Results 1 to 23 of 23
Thread: Shifting thud movement below car
    Cod
    Cod is offline
    VZ Executive
    Oct 2009
    Default Shifting thud movement below car
    I tried asking this before in another post but it disappeared for some reason O_o
    I'll try explaining this best I can and hopefully someone can offer me advice. My 2006 VZ auto has a clunking/shifting movement below the car, it seems towards the rear.
    After braking then accelerating I’ll feel something move and give a light thud sound, I notice it more so if I’m accelerating out from an intersection turning at the same time. I've found that I can get it to lightly "thud" over and over if I gently tap the throttle when the car is coasting very slowly (about 20kph). The car will also do it when shifting gears from 1st to 2nd or 3rd (only after I've been on the brakes which I assume shifts the loose moving part forwards).
    I've had the car up on a hoist with the mechanics pushing and pulling at the transmission, rear diff etc. but not luck in finding what it is.
    I'm thinking some worn bushes or mount somewhere could be doing it? Car has done 97,000kms, the problem was there when I bought it a couple weeks ago.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I have a Senator that is doing the same thing. I think it is the diff mount bush. Or it is the diff itself.
    Visit my Facebook page
    Cod
    Cod is offline
    VZ Executive
    Oct 2009
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Yeah I think it's something around there, there's no "clang" or metal on metal sound, it is more of a deep thud so i'm thinking rubber or plastic bush sliding around(with weight behind it) somewhere.
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    change diff oil, see if it helps over a week......... if not, get ur diff and or universal joint checked.
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    Exidor's Avatar
    Exidor is offline I come in peace.
    Used Martian spacecraft
    May 2008
    Earth. For now....
    Mine has a thump too when changing to third
    under a light throttle.
    There is also a dull muffled "let me out" coming
    from the boot region. Gotta check it out one day.
    I'm not afraid.
    vb sle
    Nov 2008
    az_sv6's Avatar
    az_sv6 is offline coudnt aford a v8
    vz sv6
    Sep 2009
    western sydney
    yeah i get the same thing. i can go weeks without it happining but some days it will happen over and over again.
    the hole car jolts when it happends
    VZ SV6 && 180sx
    Mar 2008
    I get this all the time.. Will get it 100% of the time in a drive through, when driving really slowly, will thud a few times.
    Will also thud when im reversing while turning. It's bloody annoying. I'm getting my diff oil changed soon, and the nolathane diff bush, will let you know how that goes.
    I've also heard it's just the A5 gearbox.. But if people are getting it in the 4sp, then I guess not..
    WTB: VZ Chasers
    JBDrifter's Avatar
    JBDrifter is offline Now in a Calais
    VZ Calais & VT Exec Wagon
    Oct 2006
    I'm glad mine doesn't do this! When I was looking for my new car I was considering a BA/BF XR6 and they ALL had the diff thud problem, which turned me right off them! I had heard that some VZ's also suffer from it, but none of the ones I drove had it. I'll consider myself very lucky as it seems to be quite common... or I'll probably jinx myself here by posting this lol.
    Cod
    Cod is offline
    VZ Executive
    Oct 2009
    After seeing others also getting the same issue it seems to be a common fault with the VZ's, surely a mechanic somewhere has seen a lot of this and would know what needs to be fixed/replaced.
    06 VZ Executive
    Nov 2008
    My Auto VZ does this too. Not very often, as a previous poster said, usually when crawling really slowly, i.e. stop/start of a traffic jam.
    I've never been too worried about it..... clunky diffs + commodore = normal! LOL!
    JBDrifter's Avatar
    Oct 2006
    Quote Originally Posted by Cod View Post
    If they're anything like the Ford BA/BF then no, nobody has a cure for the problem. My dad owns a BA MKII XR6... had his diff replaced 3 times under warranty but still no fix. He's been a Ford man all his life but says he'll never buy another one in his life (I don't believe him lol... we'll see).
    Cod
    Cod is offline
    VZ Executive
    Oct 2009
    Kal123 I just had a look at those nolathane bushes, i think it might be the way to go and sounds like from their description they correct the problems we're having. Can't paste the description from the PDF catelogue because they've "secured" it for some reason.
    http://www.nolathane.com.au/catalogu...ogue_Ed9.0.pdf
    Anyone who's interested open that up and search for "differential" until you get to the Commodore Differential Mount Inserts section.
    I was going to get one of those but it suggest in the description to get the Rear Cross Member Mounts as well with the diff bush, didn't want to waste money getting the other mounts but at the same time i dont want to have to place 2 orders and making 2 visits to the mechanic for installation.
    Cod
    Cod is offline
    VZ Executive
    Oct 2009
    I'm a bit impulsive so i've just bought the nolathane bush i was just talking about, getting it put in this afternoon, i'll let everyone know how it goes.
  15. #15
    Vz Sv6
    Jul 2005
    I was just about to post this very same topic!
    Well I just picked up a vz sv6 2 weeks ago and have since noticed the same thud sound coming from the rear when mainly reversing and turning.
    When i bought the car I had it inspected by State roads which did not even mention the issue, now i am hoping to get it fixed with their warranty they provide
    Let us know how the replacement mount goes and the total cost please
  16. #16
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    ahh the old umm,,,, im trying to think of the term here.......... cyclic knock they call it,
    caused by the outer splines of the cv shaft being undersized and slightly twisting causing the knock,
    there was a fix kit for it, unsure if you can buy it, but you need to swap a couple of parts on the cv shafts i believe to an uprated spec spline, and apply loctitie to the splines, let the car sit overnight to set and off you go again
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
  17. #17
    Exidor's Avatar
    May 2008
    Earth. For now....
  18. #18
    Vz Sv6
    Jul 2005
    Quote Originally Posted by andyman View Post
    The link above applies to non lsd differentials as i have an may 05 vz sv6 wouldnt i have a lsd? does it affect lsd aswell? what would the cost be on this fix?
    Jezza
  19. #19
    Exidor's Avatar
    May 2008
    Earth. For now....
    LSD optional on SV6.
    Check compliance plate or stick your head
    under your ride to find out.
    I'm not afraid.
  20. #20
    Cod
    Cod is offline
    VZ Executive
    Oct 2009
    The nolathane bush didn't fix the problem, still clunks from 2nd to 3rd. Costs $49 for the part and half an hour labour to install but is done in about 15 minutes.
    I'm going to check out that cyclic knock link.
  21. #21
    VZ Commodore Executive Wagon
    Apr 2011
    Frankston, VIC
    I had a mechanic look at mine nearly two years ago when I had the same noise. Worried the hell out of me, as I use my car for work. The mechanic said it was the UV Joints (only mine was only the drivers side). I still haven't had them replaced or repaired, and I hardly hear the noise now, it comes back sometimes, I'll get it fixed eventually. The whole car needs a good service, and a few other things done to it first (like, fix the oil leak!).
  22. #22
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
  23. #23
    '04 VY II Calais
    Oct 2010
    Bayside, Victoria
    Quote Originally Posted by impulsive View Post
    Extreme Thread revival...
    Good thing too. My car is doing the same thing. Haven't been too worried about it, it's more annoying than anything. Has anyone found a fix for it? By the way mine is an LSD and 4 speed auto, if that matters
  1. Idle Thud
    By CommodoreMan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-06-2009, 04:32 PM
  2. speaker thud
    By sxc_sound in forum Car Audio
    Last Post: 08-11-2008, 06:00 AM
  3. Thud when applying the brakes...???
    By ruredi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-09-2006, 11:53 PM
  4. engine thud
    By VSIIBerlinaL67 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-03-2006, 11:43 PM
  5. Dull Thud
    By DJ Majah in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-03-2004, 10:46 AM
