Page 1 of 3 123 LastLast
Results 1 to 25 of 62
Thread: Gas Peddel Lag
    VZ Executive Wagon 2006 & VR Executive Sedan 1993
    May 2004
    Australia Victoria Geelong
    Default Gas Peddel Lag
    I recently replaced my peddel's for the HSV Sport's peddel's in my VZ Exec auto.
    Now for the gas peddel the whole unit had to be replaced but after this I now have a lag in the gas peddel response for example just pressing a little on the peddel gives no response press more then it slowly start's to move the car.
    Is there a procedure for the gas peddel unit replacement to make it re-learn or do I have to take it to like Holden dealer ship to have it reset.
    VZ Executive Wagon 2006 Hot Red, 18" Genuine Holden Rims, Window Tint, Kenwood MP3 Deck, Satin Chrome Highlights, Chrome Exterior Highlights. My Ride Link
    VR Executive Sedan 1993, White, 15" Aftermarket SS Rims, Sony MP3 Deck. (Currently Being Restored) My Ride Link
    Exidor's Avatar
    Exidor is offline I come in peace.
    Used Martian spacecraft
    May 2008
    Earth. For now....
    VZ SV6 && 180sx
    Mar 2008
    May 2004
    V8 pedals into V6?
    Don't believe they are compatable.
    Quote Originally Posted by Kal123 View Post
    It is for a V6 it's not responding as it should is all I'm just asking if there is a procedure that has to be done when they get replaced ?
    StealthCalais Guest
    I just installed a set in my car last month... what you should do -
    On your new pedal, therell be a small raised cover on one side (of the main big black box - main assembly thing) with a sticker on it with a barcode etc. Now youll see theres 4 or 5 very small torx screws on there, undo these and the little plastic shield should lift off. You'll notice theres a chip and carbon bits in there so you know you have the right piece!
    Do the same to your original pedal.
    Now swap the the little covers over, so the new pedal assembly has your old chip thing on the side. Becaused this chip thing seems to be the brain of the pedal and has the resistance settings etc.
    Plug her in and with a little bit of luck this should work for you!
    May 2004
    Quote Originally Posted by StealthCalais View Post
    I'm in the process of doing this now.
    I have taken off the cover with the chip and I have also discovered something else about the the cover it self it appear's to be adjustable ? loosen the screws and the cover will have movement , remove the screws and you can see that adjustment was made for it.
    I will loosen the cover on the pedal that is currently in the car now start her up and adjust and see if it makes a difference to the lag or not.
    May 2004
    Sorry for not getting back on this.
    I was very successfull I didn't need to swap the cover's over at all.
    I removed the the sports pedal loosen the screws holding the cover in place moved it far to one side tighten screws and tested the result was a very big lag in the pedal.
    Loosen screws again and moved cover to the other side and tested result was zero lag lag was totally gone so I bolted it back in and took it on a test drive and I was extremely happy.
    Funny thing too the gear box seems to change better from take off as well.
    VZ SV6 && 180sx
    Mar 2008
    Cool, good to know. I plan on installing mine shortly, cheers for the tip!
    WTB: VZ Chasers
    Mar 2009
    thanks for the info mate,
    just wondering if you had a link to the pedals you bought that are made to suit the v6?
    cheers
    VZ SV6 && 180sx
    Mar 2008
    VZ
    Feb 2007
    any further updates on this guys?or photos of what exactly to adjust to get rid of the lag would be good.cheers
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Quote Originally Posted by AussieHolden View Post
    Id rather just get the car tuned, rather than play around with a few screws. All ur doing is just adjusting the pedal play. In a few months you'll probably have to adjust em again.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    05 VZ SV6 With VCM tune by CHE
    Mar 2009
    Quote Originally Posted by PaulSV6 View Post
    Hey Paul a VCM tune does not fix the shitty Electronic throttle that is in the VZ unfortunately. It gives it more grunt down low but the throttle is still crap. The new VE SIDI SV6's are soooo much better in the throttle setup, and they go like stink too.
    PaulSV6's Avatar
    Jun 2008
    Castle Hill
    Quote Originally Posted by torana355 View Post
    Cheers for that Paul.
    Yeah i know hey, my dad is getting a SV6 sportswagon in April
    The Blue One
    Quoted for truth
  15. #15
    Exidor's Avatar
    May 2008
    Earth. For now....
    There is some (very little) adjustment on the potentiometer cover.
    It has elongated screw mounting holes.
    Had a play with it last night. Twisted the cover as far
    as possible anti-clockwise.
    Tranny now kicks down more readily. Or is it just me?
    I'm not afraid.
  16. #16
    LthlThrt's Avatar
    LthlThrt is offline Chef Jay in Port Douglas
    02 VU II SS
    Mar 2009
    Port Douglas
    i know that this is for a VZ but im planning on doing the same for my VT...would it work the same or would it be a different procedure?
  17. #17
    Mar 2009
    Quote Originally Posted by LthlThrt View Post
    VT's have a cable controlled throttle setup mate. I wish the VZ's had a damb cable too.
  18. #18
    LthlThrt's Avatar
    02 VU II SS
    Mar 2009
    Port Douglas
    sweet so itlll be pretty simple then right? i just dont want to screw anything up. especially with these sort of controls haha
  19. #19
    PaulSV6's Avatar
    Jun 2008
    Castle Hill
    Yes, but on cable throttle setups you adjust at the throttle body where the cable connects.
    The Blue One
    Quoted for truth
  20. #20
    VZ
    Feb 2007
  21. #21
    VN V6 Exec Sedan
    Dec 2009
    Laverton
    Ok guys so before i pull the VZ to bits will this adjustment work on the standard pedal setup??
  22. #22
    PaulSV6's Avatar
    Jun 2008
    Castle Hill
    Going by what these guys have posted, yes it can be done.
    Im going to try this out when i get my HBD pedal from NVU in the next few weeks.
    The Blue One
    Quoted for truth
  23. #23
    VN V6 Exec Sedan
    Dec 2009
    Laverton
    Though they both seem to be talking about their replacement pedals, but wait i guess both pedals covers have to come off to swap chips which was the first theory. Sounds good enough to me. Break out the tools!!
  24. #24
    VN V6 Exec Sedan
    Dec 2009
    Laverton
    Well i saw what you guys were talking about, i found the Accelerator pedal worked best if you twisted it all the way to the right and then tightened the screws back up. this is with the whole pedal out in your hands face up. I almost went to undo the whole bracket monstrosity until i realised the pedal itself has two 10mm bolts holding it in, much easier. Yet to go for a drive. Will take her for a cruise when its cooler tonight.
  25. #25
    PaulSV6's Avatar
    Jun 2008
    Castle Hill
    Quote Originally Posted by DeathVZaudiO View Post
    Mate, wat did u twist all the way! are you talking about the pedal?
    Can u take some pics!
    The Blue One
    Quoted for truth
  1. Break peddel making a tightening noise.
    By anonymousmoose in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-01-2009, 01:03 PM
