Results 1 to 11 of 11
Thread: BCM Issue
    the_trademarc's Avatar
    the_trademarc is offline The Cult Of Personality
    E-Series 1 Clubsport R8
    Feb 2008
    SE Melbourne, VIC
    Default BCM Issue
    Hey guys,
    I'll give you a background of my situation:
    About 3 months ago, I started to notice my SV6 having a few electrical problems, especially when starting up. I've got aftermarket HID Xenon's on my car, and when I unlock it, I notice that one of the globes doesn't light up, and its just the standard globe. This would happen once a week maybe, very intermittently, especially when its cold. I would have to turn the Auto Lights off and then on again to get them working.
    On top of this intermittent problem, my radio would intermittently turn off as well. This is a lot more common than the headlights, and quite often would be two or three occassions within one minute, sometimes not at all. Very strange.
    Anyway, I figured I could wait it out until my next service (which is in 1000km...), but then I noticed it happening a few weeks ago again, as it got hotter here in Melbourne.
    The kicker for me was last night, driving home on the Monash Freeway at 1am, and all my lights went off and on again! Including the headlights, interior, radio, and I assume my rear lights. It was only for a second, but scared the sh*t out of me, doin 115 (what speed limit??) on a freeway in a black car.
    I called Holden today, and they reckon the Body Control Module needs to be checked and reset, and so I've booked my car in for a service as well to get it sorted, but has anyone else had this problem at all? Last night got me seriously concerned.
    VZ 06 Exec
    Dec 2007
    Sydney, NSW
    Why not just pull off the negative battery terminal for 10 mins and see is that fixes it. Helluva lot cheaper than getting Holden to do it.
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    yeah, i've heard of it doing this but i would speak with dr.bob instead of getting holdens tto do it, especially if you can live without a car for a few days.
    he'll repair it rather than holden replacing it and you having to purchase new keys to go with it.
    Chev badges are an instant fail
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    Sounda like an earthing issue.......... either that or your draining too much power and your alternator is going?.....
    If you got car amps, check those too...... I had an amp plauging my last car for months with weird problems.
    If your car is running like 2 car amps in the boot, try running an additional earth cable........ from the - battery to say where the front of the fuse box screws onto the chassy near the battery there (make sure u sand it down).
    But honestly could be anything....
    PS. Could be something to do with your aftermarket HID Xenon's having some odd short....
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    Feb 2008
    SE Melbourne, VIC
    Quote Originally Posted by Danoz View Post
    Yeah well I did that, and also pulled apart the HID kit and put it together again, and it worked fine for about 6 weeks, then it started up again
    Quote Originally Posted by bigdaddycool View Post
    My radio is stock so I don't believe it's anything related to that, nor the HID's (see above). It may be the alternator, because I think it only started happening after my lights stayed on at the shops and needed to get it jumped, but my battery seems to be holding charge quite well, so I dunno.
    What I will do though is make sure Holden don't replace anything, because I'm sure its not that serious, i.e. the car hasn't completely melted down yet.
    VZ Exec
    Aug 2008
    Keilor
    It will be BCM. About $400 and 2 remotes programmed I got quoted from Holden. Common problem for some reason mostly on earlier build date vz's
    Feb 2008
    SE Melbourne, VIC
    Quote Originally Posted by [QLIMAX] View Post
    Ah cool thanks, at least I have a comparison cost.
    And mine's is a June 05 build, so I would say that would be a later build date VZ.
    I'll let you know of the outcome from Holden (booked in for the week after next)
    05 VZ EXECUTIVE
    Nov 2009
    Exclamation BCM problem with Vz 05 Commodore
    Hi Guys,
    I;m facing a problem with my Vz 05 commodore sedan that when i lock/unlock my car with remote, the left side blinkers stays ON occasionallly (4 times out of 10). I have been told that it happens due to sticky on-board relay on Body control module.
    the replacement cost varies between $250 ~ $750 or so....
    So i need to use this forum to know the best solution and the costs involved?
    i live in west sydney.
    tha
    nik
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    ^^^I get that to. Ive just learnt to live with it. Such a small issue, i dont worry about it, i just lock or unlock the car again.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    ashbox's Avatar
    VZ SS 6 Spd
    Apr 2007
    The Car
    Quote Originally Posted by PaulSV6 View Post
    its all good to do that but the prob will eventually get worse.
    i had mine fixed at holdens for $400 including new keys, i haven't had a prob since.
    my suggestion would be if you can go with out your car for a while see if Dr.bob (on here) can fix it.
    he'll def be cheaper than the road i took but i was only with ou my car for a day.
    Feb 2008
    SE Melbourne, VIC
    Yeah that's what I thought at the start, no biggie, just turn the lights off n on again and their back to normal.
    Radio switching off intermittently while driving, or using the power windows, or indicator, ok, annoying, but still can live with it.
    When all my lights inside and out went off and on on the freeway, that's when I thought, shit this is getting worse. You don't want the electrics to all crash on ya in that situation.
    My dealership's pretty good, they've quoted me around 300, plus 412 for the 90k service and a courtesy car, so I'm happy to fork that out if it means the problem goes away. Haven't had any problems with them so far, so touch wood they do well here again
LinkBacks (?)
  1. issue
    By vx6 in forum General
    Last Post: 27-06-2009, 02:12 PM
  2. Someone please help me with this issue.
    By kizza_VL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-11-2008, 08:23 PM
  3. VX Series 2 Executive - Start Issue + Boot Button Issue!
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 02:28 PM
  4. Here's a new one... (VE Issue)
    By CSP in forum VE Holden Commodore (2006 - ?)
    Last Post: 05-04-2008, 05:33 PM
  5. LPG/VT Issue
    By tdub in forum The Pub
    Last Post: 30-05-2006, 07:28 PM
