Page 1 of 2 12 LastLast
Results 1 to 25 of 33
Thread: pleaseeeeee .. how to fix intake OTR ??
    commodore vz v6 berlina
    Nov 2009
    Default pleaseeeeee .. how to fix intake OTR ??
    hi guys ..
    how are you ??
    please if anyone can help me about my problem ..
    my promblem is .. i was bought a cold air intake OTR that above the radiator newone
    but i dont know how to fix it ..
    i was tried alot & alot & i went to mechanical to do it .. but no benift .. no body has any information about fixing it
    pleaseeeeeeeeeeee help me .. if there any pictures or images that can help me
    Nov 2009
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    Can I first say that you are new to the site obviously.....so welcome.
    Secondly, there is no need to type in red font in large size with double spacing. Its quite annoying actually.
    Thirdly, alot of us have been on this site for a while and have seen new members continually post the questions that have been asked and answered before. Please use the search function. There are threads regarding OTR intakes that will help you.
    Again, welcome and please search before posting otherwise myself and others may not be as friendly or helpful in the future
    Nov 2009
    ok my dear
    i will do that
    thanks for altering me .. and sorry because i am new here
    thanks
    Nov 2009
    sorry . but i dont find any thread talk about ( how to fix the intake OTR )
    please can any body help me
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    ive heard you may need to lay the radiator back a fraction by undoing the top mounts for it to fit
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Nov 2009
    Quote Originally Posted by andyman View Post
    yes i was do that - cut some plastic of radiator to lay the intake - but when i switch on the car it stop of work ..
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    vtcommodo3800's Avatar
    vtcommodo3800 is offline Got me a v8!
    2007 VZ SS Thunder
    Oct 2005
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by dr.lumina View Post
    have you got the airflow sensor plugged in, the sensor in the right direction, and if you had to extend the wires, join the wires correctly?
    Nov 2009
    Quote Originally Posted by SabbathSS View Post
    How much of what did you cut off?
    i was cut the small portion to i can lay the new intake
    the location of intake is ok and it is go to the throttle all right but the problem is the car not work after fixing the new intake ..
    thanks for your interest
    Nov 2009
    every thing is ok ..
    i was extend the maf wires as ok ..
    and put the maf in right direction ..
    and close the hole that related to oil vaporation
    but no benift
    Nanos's Avatar
    Nanos is offline Not a Mod
    VXII LS1 Berlina Wagon
    Aug 2007
    Frankston
    Nov 2009
    these are some pictures of my fixing the intake
    the maf is putted in its place as right direction .. and extend its wires
    the oil vaporation hole was closed and filter was fixed connected to oil hose
    and this is the oil vapor filter i was use it
  15. #15
    Nanos's Avatar
    Aug 2007
    Frankston
    unless im wrong but you havnt go tthe maf installed. the first pic is the IAT sender(intake air temp). You should have a sensor between the OTR flange and the throttle body flange. this sensor is the MAF. it looks like a tube with a plug on it for a lead.
  16. #16
    Nov 2009
    immmmmmmmmmmm .. you mean this one ??
    this is the maf ( mass air flow sensor ) i was take the inside plug and put it inside the intake as directions
    and if i want to install the whole maf ( that with tube like in the previous pic ) noooo space is there
  17. #17
    Nanos's Avatar
    Aug 2007
    Frankston
    if the car wont run after these mods it sounds like the maf maybe damaged.
    there is no way i would rip the maf aprt, even if a manual said so. they are very sensitive and easy to damage.
    try and find a original maf from somewhere, put your standard air box back in and then see if it runs. if it does then you know the maf is the problem
  18. #18
    Nov 2009
    immmmmmmmm ..
    no the maf is ok .. not damaged .. the evidance is when i return to the stock intake the car is run perfectly
    i dont know what is the cause .so. i search about any pic that talk about any directions to fix otr on vz v6
  19. #19
    Nanos's Avatar
    Aug 2007
    Frankston
    the car should run with the otr as long as the maf is installed. there is no real difference between runnig a otr or airbox. im not to sure with the vz but is there a IAT as well. make sure that is connected.
    apart from that im out of ideas
  20. #20
    Cod
    Cod is offline
    VZ Executive
    Oct 2009
    Even if the MAF isn't plugged in or not working the car should still start and run, it'll just give you an error beep and run rich? I believe.
    If it's not starting at all with the OTR then there has to be something else you've missed, something disconnected or blocked intake somewhere.
  21. #21
    Nov 2009
    Quote Originally Posted by Cod View Post
    Even if the MAF isn't plugged in or not working the car should still start and run, it'll just give you an error beep and run rich? .
    exactly like i think & said that .. what is the releashionship between foundation of maf in intake and running of car ??
    no releashion at all .. if no there or not work maf the car will run ..
  22. #22
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Pretty sure you cannot remove the sensors out of the MAF and fit them inside the CAI, the MAF uses sensors that detect certain resistances in airflow but need to be inside the specially cased housing.
    it doesn't look like you have the maf connected in those pictures, MAF should have around 4-7 wires (not sure exactly) and that sensor in the picture looks like the IAT, if your not meant to use the maf then you probabley need the computer tuned to not use the MAF sensor and use something else like MAP or the other sensors.
    If the MAF is removed it will run very poorly in some instances the car will not run/idle.
    Is the car cranking over?
    Please use a little better english as im finding it hard to understand you.
    basically, NO MAF + CAI = NO RUN, NO MAF + Computer Tune + CAI = RUN
    Gas, Ass or Grass nobody rides for free
    Quote Originally Posted by vsv8berlinawag View Post
    You tell him (coz you are right)
  23. #23
    Nanos's Avatar
    Aug 2007
    Frankston
    the maf is a important part of the car. im fairly sure the vz v6 is not like the ls1 that has a second fuel table to fall back on to.
    if the maf is not there then the computer can not set the maps needed to run. i could be wrong but i know with my wagon i couldnt just unplug the maf. it would stall the minute i did that. it wasnt till i got my tune done that i could unplug the maf.
  24. #24
    Exidor's Avatar
    Exidor is offline I come in peace.
    Used Martian spacecraft
    May 2008
    Earth. For now....
    Just to clarify.
    The IAT on the Alloytec is
    integrated into the MAF.
    Reinstall the "old" intake plumbing
    and see if you car will start then.
    I'm not afraid.
  25. #25
    ScoHar's Avatar
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Quote Originally Posted by Exidor View Post
    Just to clarify.
    Ok so is that the plug for the MAF that he has coming out of his CAI?
  1. normal air intake vs pod filter vs cold air intake: fuel economy
    By existentialist in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2011, 09:38 PM
  2. intake mod
    By miltiadis_s in forum General Discussion
    Last Post: 02-07-2008, 08:09 AM
  3. k&n intake kit
    By bern5 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-04-2008, 03:04 AM
  4. air intake
    By WhiteLightning in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-04-2007, 08:06 AM
  5. Air Intake (which is the best one)
    By smithster in forum Straight 6 Development And Modification
    Last Post: 07-09-2005, 08:40 PM
