Results 1 to 3 of 3
Thread: lowering my vz ute. NEEED ADVICE!
    vz commodore ute
    Nov 2009
    Default lowering my vz ute. NEEED ADVICE!
    hey guys
    im new to just commodores just need som advice.
    iv got a 2004 model vz commodore ute. (full stock)
    i am looking at lowering it.
    but in the future im going to put 19s or 20s on it.
    i ride motorbikes most weekends also. and the back drops a fair bit. should i fit a air bag system?
    with takin consideration of all this i want it to be as low as possible.
    what springs do i put in?
    and also whats a camber kit
    will i need one?
    thanks.
    GetToDaChopa is offline Blues Brother # 2
    The Blues Mobile
    Dec 2008
    Western Sydney
    Super Lows all round will do the job for you. Since Commodores sit higher on the back, when carrying stuff in the back it will level out for you, but otherwise some people put super lows on the front and ultra lows on the back. You will need a camber kit so that the wheels don't look like this:
    (extreme example)
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    when i had my wagon on sedan superlows, so sort of equivelent to wagon ultralows, on 235/40/18's it never scrubbed the insides,
    generally the vz's are ok unless you make them as low as possible,
    id lower it and mointor the camber wear once its lowered, cause it'll probably be ok
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
  1. neeed advice
    By pac3y in forum Car Care Products
    Last Post: 02-09-2009, 11:35 PM
  2. Advice on lowering my SV6
    By StyLeZ in forum VE Holden Commodore (2006 - ?)
    Last Post: 01-08-2009, 05:40 PM
  3. Lowering Advice
    By 89berlina in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-10-2008, 11:10 AM
  4. need advice on lowering
    By 97459579 in forum General
    Last Post: 10-08-2008, 10:31 PM
  5. lowering advice
    By timmyscommy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-04-2006, 02:49 PM
