Results 1 to 20 of 20
Thread: vz alloytec not starting
    vz atec
    Nov 2009
    Default vz alloytec not starting
    hey, i have a VZ ALLOYTEC EXECUTIVE. i'm haveing problems starting the engine, it will start but only if i turn the iginition on and remove the engine managment relay, replace it and turn the key. then the SVS, check drive tran, ABS falt and safty mode show on the dash which allows me to cruse at 15kmph. the car has had an ABS falt for about 50000ks and the 60000k service has been showing for the last 40000ks, it has been serviced but i could not remove the dash reminder.
    anyone with the same problem?
    VZ 3.6
    Feb 2009
    North of Adelaide
    sounds like its in 'limp home' mode.
    didnt give it a thrashing, while it had low oil etc, before this happened?
    Only thing i would suggest, which you've probably already done, is disconnect the battery for a few mins, then reconnect it
    "And i gave that man directions, even though i didn't even know the way; because thats the kinda guy i am today "
    vz atec
    Nov 2009
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    send it to a mechanic with a scan tool fella,
    your not gunna fix this one easily without one to point you in the direction of the fault
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Vz Ute 2005
    Nov 2010
    Aberdeen
    Hey everyone, Im new to the forum and not really sure how they work. I have a problem with my 2005 Vz v6, since i bought it, it has taken a while to start. It will crank for awhile and then it sounds like it dies down then it will start after another few seconds of cranking. I have changed fuel filters, oil filters, spark plugs, injectors, i always run it on good fuel but yet it still doesnt start good. Has anyone else had this problem, or know how to fix this?
    Thanks Gus
    '07 VZ Acclaim wagon.
    Sep 2010
    Mulgrave, VIC.
    Quote Originally Posted by v6vz View Post
    Thanks Gus
    Erm, battery?
    Need a part number? PM me.
    Luke.
    VZ SV6
    Nov 2010
    Where the cops are few & speed cameras are none QLD
    Thanks Gus
    Yep I had that problem just recently.....started off how you describe and in the end the car would try and start for a moment die completely and have no power at all, it wouldn't even have lights and when it was being jump started the other vehicle had to rev for longer than usual before mine got enough power to kick over. Even though the battery showed fully charged (12.6 volts) on the multimeter, I took the advice given on another thread here and replaced it with a new one and haven't had a problem starting the car since.
    The cause of it all was obvious once we looked at the old battery.....it had dropped 2 cells (such a common and simple cause yet not one person thought of it haha)
    So if you haven't already, check your battery.......hopefully its as simple as replacing that
    Life Sucks? Well cry me a river, put on a helmet, build a bridge and get the f**k over it.
    vz wagon
    Aug 2006
    Wild west of Melb
    Sorry to steal ya thread but I have a issue with my wagon I dissconnected the battery to stop the check power train code flashen up when I start it as I have fixed that issue but it aint had the scanner on it to clear it was told the bettery will do the same but when I tried to start it after it wont turn over and the engine control relay clicks if the key is in the rite spot they only way it turns over is to short out the starter relay and it turns over but dont fire my mate thinks its to do with the imobiliser says there is two parts to it is there a way that I can check for codes or does it need the scanner to tell me ?
    VZ SV6
    Nov 2010
    Quote Originally Posted by Clutchy View Post
    If the immobiliser is the problem, code 31 would be showing. and the car would not turn over. Check fuel and sparks.
    As for checking for codes, see 3rd post down in this thread.........
    Vz error codes not coming up on computer
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Sounds like a lot of battery issues here, i had a dew problems and I replaced battery. Maybe the car isn't getting enough charge to function correctly? After I replaced mine not a problem
    Life starts at 200km/h
    vz wagon
    Aug 2006
    Wild west of Melb
    Quote Originally Posted by SinnieC View Post
    Were does it show the codes ? and its a bit hard to check spark wen the car dont turn over.
    The battery is just over 12 months old and never had a issue untill I disconnected it yesterday.
    vz wagon
    Aug 2006
    Wild west of Melb
    Can somebody please tell me where the codes show up whan I do the paper clip test thing ?
    VZ SV6
    Nov 2010
    think its the digital display in your dash between the revs and speedometer dials where you see your fuel per 100km etc, digital speedo, fuel per 100kms etc. Im not 100% sure though so hopefully someone can clarify?
    from the instructions on how to bring up the codes......
    on the cluster screen, it will come up with things like traction control failed, abs fault, service vehicle soon, and so on
    service vehicle soon comes up in digital display I mentioned above so the codes should appear there too.
    Last edited by SinnieC; 03-12-2010 at 09:47 PM. Reason: found extra info that may help
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    i think u hold set and mode, then turn the key to acc, it should come up with a heap of things like coolant temp, ambient temp, battery volts and trouble codes etc
    Spoken by a true member of The Committee
  15. #15
    vz wagon
    Aug 2006
    Wild west of Melb
    Quote Originally Posted by richardpalinkas View Post
    Thanks for this it worked but it showed no codes so guess its off to holden to fixed guess I better book in for a new arm and leg lol
    Is it normal for it to say ya doin 4 kays and 245 revs when the engine aint even goin ?
  16. #16
    May 2009
    Gold Coast
    lol na i dont think thats normal. mine says 0 on both... maybe get a tech2 plugged in and checked then
  17. #17
    vz wagon
    Aug 2006
    Wild west of Melb
    Yeah will have to now but just gotta get it to holden. as its my only car with a tow bar bugger so gotta get a mate to pick it up and take it for me.
  18. #18
    vz wagon
    Aug 2006
    Wild west of Melb
    ok so I did find a code today had the wire in wrong plug the 27 0 in the 2 rows of 0 in the codes is a 1 can someone tell me what this is linked to please ?
  19. #19
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Think it might be time for you to take the vehicle to a workshop equiped to diagnose your problem(s).
  20. #20
    vz wagon
    Aug 2006
    Wild west of Melb
    Quote Originally Posted by Benboy View Post
    Yes I know that and if ya read my post up the page it is going to holden I am just trying to find out befor it goes there what I could be up for thats all no harm in askin a question is there ????
LinkBacks (?)
  1. 14-01-2011, 07:47 AM
  2. 21-12-2010, 11:49 PM
  1. Alloytec Oil
    By Kal123 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-05-2012, 08:16 AM
  2. HELP!!! Alloytec oil filter cap wont come off!!!! Also clutch starting to die!!
    By _SimoN__ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-10-2011, 09:29 AM
  3. Alloytec CAI
    By VZ_SV6_NZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-06-2008, 12:54 PM
  4. Alloytec anyone?
    By one_and_only2004 in forum V6 Development And Modification
    Last Post: 18-05-2008, 08:27 PM
  5. Alloytec and Alloytec 190 Engine Specs and Details
    By Gobbles in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-06-2005, 05:24 PM
