Results 1 to 14 of 14
Thread: SV6 has lost power
    05 VZ SV6 With VCM tune by CHE
    Mar 2009
    Default SV6 has lost power
    Well i don't really drive my car hard but in the last few months my VCM tuned SV6 has been running like a pig. It just had its 90k service so the fuel filter, oil filter/ Airfilter, oil in motor and gearbox is fresh. Any ideas what could be causing this?? When i first got it tuned it would have slight wheelspin if i hit it from a standing start, now it just feels sluggish.
    VZ SENATOR
    Mar 2009
    If you floor it from a standing start, does it feel like the car takes ages to max out in first gear?
    Also, put the car in third gear doing around 30km/h and give it 100% throttle. Does the car feel jerky in acceleration?
    Cod
    Cod is offline
    VZ Executive
    Oct 2009
    Still learning about the VZ's but the car possibly has gone into a limp mode due to a fault being reported? Also there's 2 tune maps the car can switch between, if it's detected too many knocks/pings/detonation in the cylinders then it might be running on the "detuned" map.
    Problem with a VCM tune is you don't know what they've played with, heopfully they haven't turned off any ECU error/fault warnings.
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Quote Originally Posted by torana355 View Post
    Did you get the gearbox issues sorted out, Paul?
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    Mar 2009
    Quote Originally Posted by mattsv6 View Post
    Yes to both of those. The only thing i can think of is it may need a good highway run as all my driving is short trips.
    Mar 2009
    Quote Originally Posted by PaulSV6 View Post
    No, i replaced the throttle assembly and it is still jerky when at 1/4 throttle. I think im going to sell it and buy a VW GTI or an EVO 8. As much as i love Holden's they have far to many issues like diff clunks, crappy auto gearboxes and general bad build quality.
    Cod
    Cod is offline
    VZ Executive
    Oct 2009
    yeah thats's a shame, holden seem to have let the standard decline.
    Go the evo mate, sooooo fricken awesome and mitsubishi's are ROCK SOLID cars throughout with near industructable transmissions.
    VZ SENATOR
    Mar 2009
    I'd almost guarantee that your coils are the problem mate. If you have the skills to replace them yourself there's a set you can buy on ebay for around $200...
    Here's what a I've heard form a Holden employee, "they will need to be replaced eventually."
    Mar 2009
    How do i check if the coils are the problem?
    Exidor's Avatar
    Exidor is offline I come in peace.
    Used Martian spacecraft
    May 2008
    Earth. For now....
    Vz "Storm" Ute
    Jun 2010
    Townsville, QLD, Australia
    I have a Vz Storm and mines just started to do the same thing..and i'm at 112, k's..It seemed to be eating just your normal fuel, so i changed it to premium and the engine is running so much better..when i brought the ute, the guy i got it from said he put a whole new exhaust system on it including extractors..it sounded good when i first got it about 7 months ago, now the exhaust sounds like arse..would my guess in saying the exhaust on my ute could be to big for it and to free flowing which could make it loose the back pressure?
    06Calais's Avatar
    06Calais is offline Keeps me Broke
    06 calais
    Apr 2011
    Australia
    yeah guys, ive lost some power, maybe 10 to 15 %. Also it seems that from time to time she has been lunging. what I mean is that I can feel one cylinder cutting in and out or something, only there's no strange Exhaust note or strange vibration from the engine.
    The idle is only ever so slightly rough, but not enough to worry about. It also seems to be a little better when cold, but once warms up it loses power. Any Advice?
    When it comes to testing the coils. Ill have to have the Upper intake taken off anyway true? so the costs of that, then getting coils tested, then re assembly. I may as well just get the set, take the upper intake off my self, replace plugs too while I am there (even though I did the plugs only 3000k ago) and change all the coils yeah? Man. I love my car, but its starting to give me Shoots a little bit. :-S
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    if the plugs were changed properly, a metal gasket should have been installed. so the intake manifold should be able to be taken on and off multiple times. i wouldnt bother replacing the spark plugs if you only just did it, just replace all the coils if they are at fault.
    Spoken by a true member of The Committee
    WL
    Mar 2011
    adelaide
    maybe the Cats are a bit blocked up?
  1. Lost power Stearing
    By Daniel_6.0 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-03-2009, 11:04 PM
  2. Lost power ??
    By Comm99 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-11-2008, 03:18 PM
  3. you would not believe how much power i lost
    By redcv6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-01-2008, 12:30 PM
  4. car has lost its power
    By Disturbed_vegeta in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2006, 10:28 PM
  5. I lost i Just need a little more power..But HOW?
    By patullose in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-12-2005, 01:19 AM
