Results 1 to 13 of 13
Thread: Removing console panels
    BullittSV6's Avatar
    BullittSV6 is offline Donating Member
    2005 VZ Commodore SV6
    May 2008
    Adelaide, South Australia
    Default Removing console panels
    Hi all,
    The leather joining the console to the gear stick has started to come apart on my car.
    I don't think its ripped, just pulled out. Does anyone know of a method of how to get the panels off to reattach the leather?
    VK
    Jul 2004
    You'll need to take off the top half of the centre console to get to the shifter surround. There's one screw to take off underneath the little sprinloaded drawer in the centre of the dash. After removing this open up your console box and lift the top console cover. It's held on by about 6 or so clips. Here's a pic that explains it better:
    From here you should be able to unhook the shifter surround from its base, there's 4 clips holding it in. Look underneath the shifter surround and you'll be able to reattach the shifter boot.
    VZ Commodore wagon
    Jul 2009
    That says it all, except having a magnetic screwdriver helps, especially for the screw right under the radio.
    BullittSV6's Avatar
    May 2008
    Cod
    Cod is offline
    VZ Executive
    Oct 2009
    I just did my shifter boot cover, put a new one in. I found that 2 of the little plastic protruding clips were broken off so the rear of the boot cover didnt have anything holding it in place. I had to super glue that part of it down to the plastic or it would pull out exposing a gap when shifter was in park.
    BullittSV6's Avatar
    May 2008
    Quote Originally Posted by Cod View Post
    Similar to what I have but I permanently have a gap. How much was the boot and do u have the holden part number?
    If I can't get mine to stick I may get a HBD kit...
    Cod
    Cod is offline
    VZ Executive
    Oct 2009
    dont remember part number, just ask coventries or amcap and they'll track it down, was about $20? possibly
    BullittSV6's Avatar
    May 2008
    Turns out this is exactly what my problem was too. But she's all good now.
    Escape-The-Fate's Avatar
    Escape-The-Fate is offline HSV, i just want one
    VE SS, M6
    Nov 2008
    Gold Coast
    mines like that now, put it in park and you can see the leather has pulled away from the surround at the back..not sure if i wanna pull the dash apart though.
    Sticking a Chev badge on any Commodore is like putting a Nissan badge on a VL
    EOI....VE SS 18" wheels x4 with 5000k's on new tread, 2 of have very minimal gutter rash (previous owner) otherwise like new send me a pm if interested.
    BullittSV6's Avatar
    May 2008
    Quote Originally Posted by Escape-The-Fate View Post
    Its not too hard. Just follow the diagram above. What that doesn't mention is you need to pry out another trim piece before you can get access to the leather.
    Glad I did it.
    VE SS, M6
    Nov 2008
    Gold Coast
    Quote Originally Posted by BullittSV6 View Post
    Glad I did it.
    yeh, was thinking about getting the silver satin trim on the shifter anyway so when ever i get one of them i'll do it all in one hit, but for now its not annoying me much. I think super glue will do the job as said above if the clips are broken.
    BullittSV6's Avatar
    May 2008
    Yeah the clips were broken, loctite = problem solvered
    Cod
    Cod is offline
    VZ Executive
    Oct 2009
    Sounds like a common weak point on these, btw the boot cover isn't real leather :P Getting to it is easy, I looked at ASR's audio section on the forums here and found a link to a guide for doing the interior lighting mod, had a couple pics showing how to remove the center console. There's also a scan from the holden workshop manual floating around here.
    It's just clips and one screw, btw the shift knob just pulls off EASILY once you undo the torq screw behind it. I read a misinformative post on here saying you have to pull REALLY hard to get it off, DO NOT DO THAT, remove the screw and it pulls off easily.
  1. Removing sill panels
    By vrollin in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-06-2008, 08:53 PM
  2. Removing Centre console
    By YMY-88U in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-02-2007, 11:27 PM
  3. Removing centre console VK
    By VRSS in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-04-2006, 04:51 PM
  4. Removing vr front door panels to replace speakers
    By jayseventwo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-05-2005, 01:18 PM
  5. Removing The Cenre Console?
    By paradox1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2004, 10:24 PM
