Hey Guys, I want a set of 20 inch wheels for my VZ SV6
20 inch Incubus Paranormals
Lowered on King Springs.. What is involved??
hey man,
i currently have 20" paranormals on my vz acclaim lowered on ssl's all round and im telling u now its a bitch cos the off set of the rims is huge compared to stockies, u'll needa get all the guards rolled then cut out anything that scrubs and trust me even on sl's they'll scrub and im only running 225/25 r20 tyres.
what tyres u gunna run?
God, do some research mate there are a milion commodores out there with 20's on them
FAT.36L NOW RIDING IMPORT
Full 5spd Conversion For Sale PM me
Thanks for the help, i think I will do some research..
Peace
get the rims then call up pedders near you they will tell you whats involved you may need to roll the guards.
I was gunna get 20's on mine, but i stuck with 19's plus you blow a 20" tyre your screwed very expensive to buy.
The Blue One
Sorry what i was saying was,
if you get 20's and dump the car which is i think 5mm you dont need to roll.
if you wanted to super low you may need to roll the guards.
20's fit on the vz without a problem if you keep the stock springs.
sorry i should have been alot more clearer.
The Blue One
just buy rims with the correct offset, i think it's 48P easiest way to finf out is look at whats stamped on the wheels on your car now. the correct offset wheels will always fit dont forget the HVS run 19's with 245mm rubber so any 245mm rubber can and will fit
iv'e got 20"s on my sv6
looks awesome. many great comments on them.
its lowered, not sure what springs as bought it lowered.
not scrubbing on wheel arches or inside plastic panels on full lock either.
hope this helps
