Hello I assumed after reading other posts VE wheels can be fitted to older model commodores after machining, in my case a VZ. So I picked up a set of second hand VE SS wheels and brought them home. After holding one up alongside to my car to my dismay I found that the things are much larger in diameter to the regular wheel with tyre. So much so I can't see how the things could possibly fit inside the wheel arch. Is this the case with all VE wheels? Or just the SS rims are larger than normal?
Even if I could squeeze the things on the speedometer would be drastically inaccurate from the larger wheel. I need to know if all VE wheels are like this so I don’t waste any more time or money looking at them. I was originally trying to source a set of 17” SV6 rims but the damn things are hard to find, when do I come across a set they’re always too damaged for my liking.
VE SS rims are 18" & ur exec rims are 15" so obviously they are going to be larger.
Keeping in mind that VE wheel arches are much bigger than VZ wheel arches hench why they look like they wouldn't fit.
You'll need to find out the roller diameter difference between the two tyre sizes.
Tire size calculator
The above link will tell u.
The Blue One
I should have mentioned I assumed the profile of the tyre is what maintains the rolling diameter of the wheel to be right. I know 18" is bigger than 15"
But yeah in saying that the overall diameter of the SS wheels with tyres is significantly larger than a standard wheel.
I'm going to see if I can get a lower profile tyre to fit them but that will start to get costly, at the moment there's 245/45/18's on them, I was thinking maybe 245/40/18's to get the diameter down.
Thing is with that is they're still 245 wide, will that scrape inside the wheel arch of a VZ? Starting to think they're too much trouble to be worth it. If I could just find some damn SV6 17's I’ll be happy.
Edit: PaulSV6, with your calc tool you link, says a set of 245/40/18's should maintain the stock rolling diameter 205/65/15
I'll check out the price on tyres, just need to find somewhere that can machine the wheels to fit, center hub is the area that needs to be machined larger?
surely 245 will fit inside the vz guards the vz hsv's must run 245's stock? on 19inch?
245'S will fit but you'll need 245/40/R18 instead of 245/45/R18
Yep sorting all that out now, there's a place that does the machining ive found, overpriced in my opinion though at $45 per wheel plus GST so $50 ea $200 for 4.
hey mate how are ya?
i've got a vz exec 05 aswell. i bought a set of ve ss wheels the 245/45/18's and i did the 'machining' myself. literally all i did was buy a file from bunnings and sat in my lounge room with each tyre for about an hour just filing the alloy hub down from the centre of the rim. they look pretty nice on it. i am getting my car lowered for chrissy so hopefully i wont have any problems with the guards rubbings but yeah i'll roll them myself and all that. if you have any more questions about the fittings or whatever i'd be happy to help if i can.
cheers man, good luck with it.
I would strongly advise against filing them yourself, the center hub has to be PERFECT in shape and diameter or the wheel will not sit properly giving you balancing and support problems. This is normally done by a lathe of some sort that is adjustable down to .5mm as the hole needs to be .5 fraction.
If the wheel center hub has any movement or gap it won't fit perfectly on the car's hub then the load and weight of the car will be resting on the nut lugs instead, that is why people with poorly machine wheels are getting snapped wheel bolts which can cause a serious accident, not to mention insurance void after inspection. You also have to make sure you use the proper Holden wide 12mm nuts that have FULL clamping surface area on the VE wheel. Not the chrome after market ones you can buy.
If my opinion getting VE wheels to fit correctly is not worth the trouble and money.
I have fitted a set of HSV VE rims on my VZ,d 9.5" x 19" on the rear and 9" x 19" to the front had it also lowered professionally and looks tough as, no tire rubbing at all![]()
Try these guys they now and then come up with some good items at realistic prices http://holmart.com.au/online/index.htm LOOK UNDER WHEEL SPECIALS
I'm running 20x8.5" wide rims on my VZ SS, with 245/30/20 tyres.. and they fit, guards were rolled but they work :P (bare in mind i only have the 245's on the rear as they would not fit on the front without scrubbing) oh and it has king springs lows in it all round
Hey Bro, Im running 18" VE SS rims on my VZ exec sedan, 235x40 18's. She is still sitting at standard height at the moment too, looks like i put a freakin lift kit on it. I payed 1200 machined and fitted DRIVE AWAY. They look sweet as on a VZ.
I got ve ssv rims on vz sv6 . Love em. Had to get the center milled out to fit. Came with 245/40's n only the rears rubed on guards... Poped a tyre yester day on rear had em on 4 a year.. Went to bridgestone today n put the 40's on the back n rolled the guards n got 245/35's (hankook) for tha front.. Dont think theyl rub anymore.. $650 later.. When the potenzas go ill put 35's on the back aswel... The 45's only rubed when i had boot full of piss n a couple of blokes on the back... Oh yeah its not lowerd either... But soon
probly my favorate holden rims![]()
And my spedo's out too by 5 kph i think?
i got a set of ssv's (19 inch) and thinking about 245/35/r19 and my car is vz exec lowered on sl front and ssl rear anyone know if they will scrub or just to be sure drop back to a 235?
Sticking a Chev badge on any Commodore is like putting a Nissan badge on a VL
EOI....VE SS 18" wheels x4 with 5000k's on new tread, 2 of have very minimal gutter rash (previous owner) otherwise like new send me a pm if interested.
I thought VE SS rims are 19"
Just to clarify:
VE SV6/SS are 18"
VE SSV are 19"
The Blue One
Sorry to dig up an oldthread guy's but i just picked up a 05 vz the other day and it has ve ss rims on it. I know they've had to be machiened but how do i know if it's been done profesionaly and should it have a camber kit for the larger rim's (19's) it's lowered on king sl springs. Any feedback would be much appreciated
The hole in the centre of the rim should fit snugly over the hub, if its a loose fit its no good.
If they are 19s theyll be SS-V rims.
Silver Certified.
Sorry to dig an old thread but I got flung a set of 19 inch rims with 245/40/18 tyres on them from a friend
Of mine for my vz .
Just checking whether they will fit or not as I don't have my car at the moment.
Tyre guide says I should use 235/35r19 on front and and 245/35r19 on the rear
At the moment my vz exec will be lowered to sl on front and ssl on the rear?
If anyone could clear this up I would be very greatful
245/35R19 all round is the correct size, I run these with no issues.
Silver Certified.
