im trying to find my traction controll sensors at the wheels, does anyone know where they are exactly or how i remove them
they are mounted on the diff.. not at the wheels.
Research has shown that men usually sleep on the right side of the bed.
Even in our sleep we happen to be right.
Powered By Garrett
i think no there traction in front wheel .. but not sure
There is traction on front, sensors go in behind the rotors the rotors have teath
The traction control setup works with hall effect sensors.
MaT
Originally Posted by garth
traction control is worked out by the speed sensor pick ups off the wheels alongside abs,
you disconnect those, you dash will be lit up like a christmas tree
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
yeh they are, i have had the car for 12 months and havent changed a thing but now every now and then i get a ESP fail and im not doing anything stupid around corners or anything just straight line.
thought i would try cleaning the sensors before taking it to the evil holden service centre where they will just tell me that i was going to hard around a corner
well the only thing really special with esp is lateral g force sensor, other than that it mainly uses the abs sensor for wheel spin and speeds etc
There should also be a steering wheel angle sensor
for the ESP.
I'm not afraid.
