Results 1 to 16 of 16
Thread: Cleaning injectors
    VZ 06 Exec
    Dec 2007
    Sydney, NSW
    Default Cleaning injectors
    Apart from removing the injectors or putting a bottle of injector clean in the tank anyone got any hints,tricks or techniques to get their injectors super duper clean?
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    VZ 06 Exec
    Dec 2007
    Sydney, NSW
    Yes I know that works, but as my OP says I would like to avoid removing them. Ive heard a splash of acetone may work.
    Set of thongs
    Dec 2005
    Stonedville
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    filter kits for the injectors are cheap on ebay rip the old ones out the injectors run some toluene based carby cleaner through the injectors to clean the crud out best way is with the injectors out fill them with toluene pulse them a couple of times with a square 9V battery then refill and let sock for an hour then reinstall the new filters and slap them back in the toluene is nasty shit it eats just about anything known to man and works great at cleaning injectors
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Put a few tanks of Premium Unleaded through it. Fuel is cleaner and burns cleaner. Well known way of removing gunk from injectors, fuel system, valves etc. Cheaper than buying bottles of additive.
    VZ 06 Exec
    Dec 2007
    Sydney, NSW
    в∞ѕтεכ √&
    Jul 2008
    NZ
    paint shop or just buy carby cleaner that has it as the main ingredient .they may think you are making meth if you ask for bottles of toluene LOL so be warned
    VZ 06 Exec
    Dec 2007
    Sydney, NSW
    VZ 06 Exec
    Dec 2007
    Sydney, NSW
    One more thing.. Are those filters universal? Im not sure which ones to buy...
    http://cgi.ebay.com/ebaymotors/Fuel-...Q5fAccessories
    Whaddaya reckon bout this one?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    as long as they are for bosch injectors of the same type post a link when you find some
    VXII
    Nov 2009
    Bottles of injector cleaner or whatever they call it is shite. It's way too dilute to do anything for your fuel injectors. Don't waste your money.
    Carby cleaner is great stuff, but will give you cancer. Toluene is a high risk carcinogen. Use at your own peril, or make sure you wear gloves and mask etc. Mind you, petrol also has benzene and toluene. Be very, very careful.
    I would not recommend using a 9V battery on your fuel injectors. Firstly, your injectors work off a 5V signal, and that signal only lasts for 2 or 3 milliseconds (hundredths of a second) for each pulse. By holding such a large voltage on the terminals for longer perioods than this you will damage your injectors internally by melting the fine coil windings inside and they may never work as well again. You may also cause a fire on your test bench from the arcing wire connections.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    actually injectors run off 12v and can handle being held open for long periods no worries with a 9v battery
    VXII
    Nov 2009
    Quote Originally Posted by delcowizzid View Post
    yeah, fair call. Don't know where my head was when I said that...
  15. #15
    thedeadwalk's Avatar
    thedeadwalk is offline thedeadwalk
    VS executive S2
    Sep 2009
    newcastle
  16. #16
    nil
    Dec 2009
    Another way that doesnt involve removing injectors is to run an on board injection cleaner, basically you cut off the fuel supply and run it on this cleaning solution, it cleans your fuel rail and injectors.
    We charge i think 50 bucks and unless your injectors are rooted, they come up good as new!
  1. Cleaning injectors?
    By discostuee in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-11-2008, 06:55 PM
  2. Cleaning injectors
    By Uber_Matt in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-06-2006, 01:19 PM
  3. Cleaning the Injectors
    By Mk III the HSV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-12-2005, 06:42 AM
  4. Cleaning injectors
    By killuminati in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-11-2005, 09:01 PM
  5. Cleaning Injectors
    By vinnywelsh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-01-2005, 12:35 AM
