Results 1 to 2 of 2
Thread: supercharging
    sam8s is offline yellow devill
    vz ss
    Jan 2009
    perth
    Default supercharging
    hi, this has probably been asked before but cant find much info.
    im seriously considering supercharging my vz ss 5.7L
    motor is completly standard apart from defillipo system
    ive seen the raptor and vortech supercharger kits that are in my price range and seem to have reasonable power outputs.
    are these kits safe on a standard engine or will i be risking blowing parts?, obviously ill have to keep the pressure below 8psi.
    ill be doing all the work my self, apart from tuning, this is why im thinking of the blown approach apposed to cam work as it seems alot easier
    or would anyone recommend the extra work and do the internals instead?
    also how do the 4 spd autos cope with the power?
    thanks for any help.
    TVR-190's Avatar
    TVR-190 is online now SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    most engines will handle a few psi no problem, if you plan to run serious boost then youd need to do work. In short the stock engine should be able to run the s/c at a few psi no probs
    The Black Beauty
  1. supercharging vr v6
    By Zuicider in forum Yella Terra
    Last Post: 28-10-2010, 12:49 PM
  2. supercharging my VY V6
    By lenzy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-11-2009, 10:01 PM
  3. supercharging L36......
    By lumina01 in forum Yella Terra
    Last Post: 31-01-2009, 10:03 AM
  4. Supercharging my vc..
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-06-2006, 03:20 AM
