G'day all,
I'm suspecting that the throttle body on our VZ SV6 is in need of a good clean due to carbon deposits. Does anyone have the step-by-step instructions on how to remove the intake air ducting and the throttle body?
Any help is greatly appreciated!
Regards,
Dave
Injected CNG, LNG & LPG: The only way to go better!
Carbon deposits in your TB?![]()
Wouldn't be carbon deposits. Carbon is what remains after something organic is burned. Try a couple of tanks of Premium Unleaded. Should start to clean things up. Pays to run a tank or PU every two or three fills. PU is a better product with less 'nasties' and will also keep your valves, combustion chambers, plugs and oil a lot cleaner.
Linky Take a read, Carbon build up in throttle bodys is very common. My old SR20 in my SSS Pulsar had a shitload of buildup when i used some Suburu upper engine cleaner.
We run all our cars on 98RON PULP and LPG. Based on your logic, you'd expect the throttle bodies on our cars to be squeaky-clean, right? That couldn't be further from the truth, as I found out two weeks ago with our BA XT and BA XR6.
Upon removing the intake air duct, I cleaned the throttle bodies on both BAs using a couple of old rags and a can of Nulon Throttle Body Cleaner and ended up with two JET BLACK rags. Idle quality and responsiveness improved instantly.
Regards,
Dave
Anyone?
Regards,
Dave
Remove,
That should do it I think.
- radiator shroud
- intake ducting
- wiring connector to TB
- PCV clip to TB
- four bolts to TB
Replace gasket on install.
Voila!
I'm not afraid.
Could you give me more details on removing 1 & 2 please?
Cheers!
there is 4 clips at the front of the radiator shroud, use a flat blade to pry these up and remove,
then there is 2 8mm hose clamps on each end of the intake pipe from the tb to the maf, remove that piece,
then undo the wiring connector, the clip under the tb for wiring, and unbolt the tb,
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
