Results 1 to 12 of 12
Thread: front sway bar
    vz wagon
    Jun 2009
    Default front sway bar
    was wondering has anyone fitted an aftermarket sway bar, eg whiteline x-blade adjustable or simmalar 2 there vz wags/sedan
    just trying 2 reduce understeer threw the twisty roads
    any feedback apreciated cheers
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    You want a thicker rear sway bar if you want to reduce understeer. Fatter sway bar on the front will increase understeer.
    I had a 30mm adjustable bar on my VT back in the day, it was great. The stock SS setup is good enough for me not to bother on my VZ, but it's still tempting.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    VZ SV6 && 180sx
    Mar 2008
    I've got 2 Whiteline SwayBars in my garage waiting to be installed in my SV6. (30mm Adj Fr && 18mm Adj R)
    I'll hopefully have them installed by the new year...I'll let you know how they go..
    WTB: VZ Chasers
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    ^^^I'd love to hear the outcome of this.
    Isn't there a 20mm for the rear?
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    danja's Avatar
    Jan 2006
    Just FYI, the stock VZ sedan swaybars are 25/12mm front/rear for FE1, and 26/13mm for FE2.
    So already with a rear 18mm you're talking about 40/50% increase, at 20mm thats 50/65%.
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by danja View Post
    Quoted for truth.
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    VZ SV6 && 180sx
    Mar 2008
    What happens when you install both lol?
    WTB: VZ Chasers
    VY SII HBD Calais L67
    Dec 2006
    IMO commodores are always prone to understeer due to their heavier front end and steering geometry. Two main things that combat this are lowering on good quality shocks n springs along with a sway bar upgrade (front n rear) and adjustable urethane castor rod bushes. More castor, lower roll centre and improved bushes get these things handling like they're on rails
    VYII Calais L67
    danja's Avatar
    Jan 2006
    Quote Originally Posted by Kal123 View Post
    Depends on the balance, but the more you stiffen the front, the more understeer you'll get, and the more you stiffen the rear, the more oversteer you'll get.
    If you up both in proportion, you'll get the same balance, but less body sway. Too much though and the car will get skittish.
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by chargedvx6 View Post
    I 100% agree with you about castor. For me, castor is King, and far more important than camber... but having said that, Commodores stock already have an enormous amount of castor, and the castor bush kits won't add a material amount of extra castor, so generally dialing understeer out of a Commodore usually has to come from other areas. Bu yep, you can never have too much castor... if you do you just dial back static camber and get better braking!
    Exidor's Avatar
    Exidor is offline I come in peace.
    Used Martian spacecraft
    May 2008
    Earth. For now....
    Adding 1.5 degrees on my Zed fixed the overly
    sensitive steering feel. Somewhat.
    I'm not afraid.
    vz wagon
    Jun 2009
    thanks 4 all the feedback and info guys
  1. Fitting VY front sway bar
    By Daniel 138 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-08-2009, 08:53 PM
  2. front sway bar bushes
    By mrhotdog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2008, 03:58 PM
  3. front sway bar
    By Dayvo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-01-2008, 08:54 PM
  4. V8 Front Sway Bar
    By VN Commy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-08-2006, 12:28 PM
  5. front sway bar link kit. VR
    By Hakka in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2006, 05:41 PM
