Results 1 to 15 of 15
Thread: VZ Door locking Problems
    VZ s pack ute
    Dec 2009
    Default VZ Door locking Problems
    Hey everyone Im new and been checking out this forum which has heeps of good info, but on my first post I need to ask some questions.
    Today is also the day I picked up my vz ute but I cant get it to lock, when I press the lock button on the key it starts beeping and wont lock, but the doors and bonnet are shut properly etc. Has anyone had this problem or know what its doing?
    Im not very familiar to cars with alarms and those sorts of electronics and I feel like an idiot having to ask this sort of question but what do I do?
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    If you purchased it from a car yard, take it back and have it repaired under warranty. You do have a warranty don't you ?
    dmar's Avatar
    dmar is offline kl
    vz
    Mar 2008
    had the same issue on my sedan intermittently, its the door lock actuators
    (all would lock except front passenger, which caused the alarm to honk a few times whenever i lock it)
    check both sides lock, if one doesnt, get in the other side and manually lock it, then get out, shut the door and press lock. might be a work around until you can pull the trim off and clean the actuator terminals or whatvr
    mine came good before i bothered doing that last step.
    VZ s pack ute
    Dec 2009
    thanks for the quick replies I tried locking the passenger door then locking it as you said but it still honked?
    I dont know if its what did it but early in the day I accidentally tried locking it with the spare key in the ignition and it honked then would that have set some thing in the computer? because i can manually lock the doors with the key but the central locking does the beeping thing
    Oh_Your_Blind's Avatar
    Oh_Your_Blind is offline Green means 'Earth'!
    2002 VY Executive
    Sep 2009
    Mount Druitt, Sydney
    when it goes 'beep beep beep' it means something else is unlocked..
    Quote Originally Posted by HoldenCommodoreVP View Post
    [to Mad-Biker]
    Didn't you say your arm was broken? You must have started this reply yesterday...
    VZ s pack ute
    Dec 2009
    mdmatt is offline mdmatt
    2005 LS1 Auto VZ SSZ 328.6rwhp
    Aug 2009
    pretty sure its your door lock actuators, take it back n get it looked at.
    VZS-Ute06
    Aug 2006
    Western Vic
    Yep!
    Had the same issue with mine when 40K on the clock
    could only manually lock by pushin' button or use key
    Holden replaced both actuators
    never had a problem since
    VZ-Rob
    98 Ron Powerchip: CAI: SuperLows: GTS Swaybars: Tinted: SS Grille: SS Vents: SS 2:25 Twin Exhaust: ASR Audio:
    the_trademarc's Avatar
    the_trademarc is offline The Cult Of Personality
    E-Series 1 Clubsport R8
    Feb 2008
    SE Melbourne, VIC
    Don't know much about the Ute's, but would a hard-top at the back not closed properly cause the alarm to go off? On my mate's Hilux the alarm goes off if his hardtop isn't closed properly.
    VX Executive S2
    Dec 2009
    I think your problem is more than likely a broken wire in the wiring loom that goes to the driver's side door. Check the loom at the door hinge.
    Luke0011 is offline Car Audio Installer
    VZ Berlina 2005
    Jan 2007
    mm broken wire in a vz thats only a few years old is unlikely. if the door is not closed properly or the bonnet open the horn will sound if you use the remote to lock it. The reason why is the door lock is faulty and keeps an earth present on the door sw wire. this wire as well as the 5 wire loom from the door lock actuators are linked through the body control module.
    Aug 2009
    vz berlina v6
    Aug 2007
    its definitely the actuator had the same problem, holden dealer put a new one locked fine when i left get home and it was doing the same thing, turns out the new one was faulty, maybe they had a faulty batch of these?
    VZ SV6
    Dec 2009
    Sunshine Coast
    hey guys.. i had this problem.. after researching it i figured one of my door locking mech's (solenoid) wasn't working. i took my door apart and replaced it and it started working. just check you central locking by putting in the key locking it and checking the doors if there locked..
  15. #15
    VZ HSV R8
    May 2005
    It is the door lock actuator, I had the same replace actuator all good :-)
  1. VN Door lock problems/central locking
    By VN-Corey in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-09-2009, 07:42 PM
  2. Central Locking Problems
    By Haze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-04-2006, 09:20 PM
  3. Door Central Locking
    By Maxie195 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-08-2005, 09:50 PM
  4. Door Central Locking
    By Maxie195 in forum Electrical Wiring / Questions
    Last Post: 04-08-2005, 02:58 PM
  5. Door Not Locking
    By cookie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-05-2005, 08:16 AM
