Results 1 to 7 of 7
Thread: "Fuel Gauge" Error just appeared.
    Jul 2005
    Default "Fuel Gauge" Error just appeared.
    Hi all , have a 06 VZ executive auto wagon with just 60,000 km on the clock. It has started to show a fuel gauge error on the display and the fuel gauge is showing empty even when it is full. It has always been consistently inaccurate with 15 litres remaining when the fuel warning thingy flashes. It says contact dealer.
    The car is still driving ok. Will it cause a problem or can it wait until it is a bit more convenient?
    Thanks
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Well the fact that its saying contact dealer, means it needs to be dealt with straight away.
    Also ur low fuel warning is supposed to come on when there are only 15 ltrs left, thats ur reserve amount.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    BXHD Guest
    my fuel gadge plays up too, urs would be under warrenty wouldnt it?
    go get it checked out asap if it says contact dealer. i would
    the_trademarc's Avatar
    the_trademarc is offline The Cult Of Personality
    E-Series 1 Clubsport R8
    Feb 2008
    SE Melbourne, VIC
    So the Low Fuel Warning kicks in at 15, and the very low at 5?
    Also, it is a common VT-VZ fuel gauge error. You need to have the dealer re-calibrate the fuel tank and also check the fuel injectors. I had mine done under warranty a couple years, and although I still trust my math over the needle, it doesnt fluctuate anymore.
    I can still do about 25km when it says 0km to empty though lol
    PaulSV6's Avatar
    Jun 2008
    Castle Hill
    Quote Originally Posted by the_trademarc View Post
    Not exactly, i should have clarified abit more,
    Low fuel around 20ltrs
    very low fuel around 15ltrs
    The Blue One
    Quoted for truth
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    takes aloooooot to run out of fuel.
    Yeh the issue sounds like its with your level sender in the tank. Only way is to have it checked out properly, theres no simple stupid solution to this one
    Feb 2008
    SE Melbourne, VIC
    Quote Originally Posted by PaulSV6 View Post
    That's a bloody lot of fuel for the warning light to kick in!
    Everytime I hit very low fuel, I check the system modes and it always says 5 or less L remaining.
    Theoretically then, you should be able to drive 150-180km once the very low fuel light comes on, according to the above numbers...
  1. Service "error" message
    By Happy Panda's in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-10-2011, 10:45 PM
  2. blaupunkt cd- "mechanism error"
    By lockmac in forum Car Audio
    Last Post: 12-10-2009, 07:59 AM
  3. Auto Gauge 2"/52mm Smoke Series Boost Gauge w/ FREE gauge cup
    By pepstar87 in forum Parts And Other Items For Sale
    Last Post: 16-05-2008, 01:16 PM
  4. "Shift Up" Error message *HELP*
    By dean_jely in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-09-2007, 05:17 PM
  5. Error 42 - "spark timing" fault
    By Irr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2006, 06:06 PM
