Results 1 to 10 of 10
Thread: VZ 82000, which OIL
    VS Commodore Exective
    Jun 2009
    Default VZ 82000, which OIL
    My VZ has just completed 82000KMs, should i still use 10w/30 as specified in the booklet? or go for 10/40, 14/40???? i was confused by someone saying oil grade should change after your car has done over 80000..
    Should i buy Synthetic?brand?
    any good oil filter?
    Appreciate your help..
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    As the engine wears, it will start to become noisier as time goes on. This should be conpensated by using a thicker oil.
    10/30 or 10/40 theres not much difference, wont be an issue using 10/40. I use 10/40 in my SV6 & its only done 63000.
    Ive changed to Nulon 100% Synthetic from Mobil 1 Super Syn, cause i was starting to get a lil bit of tapet noise.
    Ive also always used Ryco Oil filters, theres no need to spend extra money on high performance filters
    An oil filter is only going to perform well, if u change ur oil regularly!
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    the genuine Holden filter is only 10 bucks and when I was looking even the cheapest aftermarket filter still cost more then the genuine
    Honestly I havent noticed a difference and Im running all sorts of different oil - Castrol Edge Sport for Track days, Magnatec for every other day, Valvoline semi synthetic when the mechanic has it.
    Mines done more then 160 000 kays.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    continue on with the 10w-30, i believe the days on using thicker oil is gone, oil viscosity plays a larger role in motors these days as components (such as vvt solenoids) need a specific oil thickness to operate correctly
    ive got 94,000 on mine and still using 5w-30 valvoline durablend, runs perfect on it
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    milhouse is offline Project Beast
    VZ SSZ 5.7L
    Oct 2009
    sydney
    ok straight from a licensed mechanic and some1 who has owned is up2 his 2nd commodore. Valvaline oils!! Valvaline Oil Filters etc. I ave installed and used valvaline products on my own and mates cars (nb mates cars r high performace cars). i ave a ssz myself. A semi synthetic blend 10-30 si ideal ryt up2 130000kms. y semi synthetic? cause semi synthetic has synthetic blend in a mineral based oil so naturalli u get best of both worlds in oils. if ur car is supercharged or turbo charge onli use full synthetic has the heat from the two are so great synthetic will b able to transfer the heat quika bein a teflon base. also semi synthetic is ideal for short city trips and towing. after 130000kms i reconmend a 15w-40 tright upto 200000kms n afta that use 20w50 if ur vehicles isnt using excessive oil amounts.
    Nobody Actually's Avatar
    Nobody Actually is offline luxo barge
    VS s2 Caprice 5l = slow
    Aug 2005
    Queensland
    Quote Originally Posted by milhouse View Post
    damn, john laws is gonna whoop your ass boy. a licensed mechanic who can't spell VALVOLINE.
    **** me swinging
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    thats fine for a push rod ohv motor, but newer high spinning motors with oil actuated vvt needs a thinner oil like 10w-30 to keep the vvt components working correctly, a full mineral based oil i not good in vvt equiped cars as it will sludge in the components,
    in saying that too, ive been using 10w-30 in a mates vx thats done 270,000km for the last 50,000km and it dosnt burn any more oil than typical ecotec, so over 10,000km its on the add mark
    VSII Calais supercharged
    Mar 2005
    South Coast, NSW
    To the original poster, there's no need to change your viscosity just because of the number on the odometer. If the car is serviced regularly and still running with no noises or problems, why change?
    ....A semi synthetic blend 10-30 si ideal ryt up2 130000kms. y semi synthetic? cause semi synthetic has synthetic blend in a mineral based oil so naturalli u get best of both worlds in oils. if ur car is supercharged or turbo charge onli use full synthetic has the heat from the two are so great synthetic will b able to transfer the heat quika bein a teflon base.
    I want to know what advantages you think mineral has over synthetic?
    Car theives should be treated just like horse theives and cattle rustlers in the days of the wild west... Hang them!
    Don't be stupid. Power isn't measured by the size of your tacho
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Have a look on the Castrol site Castrol Australia for specific recommendations for their oil.
    They recommend Castrol GTX Modern 10W - 30 for VZ 3.6 2004-2005 models.
    For later model (2006), they also recommend Castrol GTX Modern 10W - 30 and Castrol Magnatec 10W - 40
    For the 2007 model, the recommendation is for Castrol Edge Sport 5W - 30 or Castrol Magnatec 10W - 40
