Results 1 to 12 of 12
Thread: computer went spaz and car didnt work
    svsex is offline big blue
    190 sv6
    Jun 2008
    Default computer went spaz and car didnt work
    we to start my car today and i turned the key and nothing happened so i took it back out and did it again then the screen went besetrk blinkers came on randomly and the my screen went all dotty and differnet pictures came up and then nothing. it just died and wudnt work, i tried to lock it and unluock it and that didnt even work
    its like the computer just had an epic crash and didnt want to live anymore, i just disconected the battery for a bit then hooked it back up and it was all good.
    just thought ide post this up in case any of u fellas had the same problem
    Cursed CX8 is offline Banned
    VY Adventra
    Feb 2008
    Walking distance to FG meets
    VP Calais 3.8L
    Jan 2006
    Ringwood, Vic
    190 sv6
    Jun 2008
    it did it again yesterday, quite annoying. might have to see the suto electrician
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    There's a possibility that ur battery is on the way out, did u check the voltage?
    Either that or u have a issue in the BCM.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    190 sv6
    Jun 2008
    Quote Originally Posted by PaulSV6 View Post
    well ive only just replaced the battery, and sorry for sounding dumb, buts whats a BCM?
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    Had a similar thing on my dad's 05 VZ Exec.......... not exactly the same...... his car randomly cut out when driving (most thing crank sensor) but after further testing.......... we found it was a switch at the bottom of the key barrel causing the whole car to go nuts.....
    put ur key in and wiggle it on start and on ........ if it does it again, see if ur dash flicks on and power cuts out on all the internals etc........ dash lights etc......
    Otherwise perhaps your key is flat.
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    PaulSV6's Avatar
    Jun 2008
    Castle Hill
    Quote Originally Posted by svsex View Post
    buts whats a BCM?
    Body control Module, its the brains of the car!
    The Blue One
    Quoted for truth
    190 sv6
    Jun 2008
    thanks,
    did it agin this morning, the engine management relay seem to be pretty much ready to brn out, so i think that might have something to do with it, also i have some corrosion on the clamps that go onto the battery terminals (chunks of white powder and so on) and im thinking wen i turn the ignition to start there isnt enuf connectivity through the conection to turn it over and the computer reads an error or somewat. anyways thanks for the help fellas
    vz executive
    Jan 2007
    melb
    mine does the same i even went and bought a new battery still does it on occasions but only when im on center rd as the missus pointed out hhmmm
    190 sv6
    Jun 2008
    well im pretty sure i found the problem, the battery terminals were not making a proper connectiokn due to some corrosion and the terminal crimp lug thing that goes gotes on the battery terminal wudnt do up any tighter and was quite loose so i basically smashed it down till it was tight and it hasnt played up since.
    excuse my reatard mechanical talk. haha
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    wouldnt hurt to get someone to quickly check it out tho and see what the logged codes are.
    Reason I say this is because there have been issues of BCM (or a similar module) failing in a similar way.
    May just be dodgey battery connections, may be something worse.
  1. vr powerchip into a nv computer will it work
    By timay86 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-01-2008, 05:55 PM
  2. will a ED ford Trip computer work in a VP holden
    By 12000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-04-2007, 07:31 PM
  3. Speedo having a spaz
    By VLishes in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-09-2006, 05:46 PM
  4. trip computer - LCD lights only half work VR Berlina
    By nielo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-09-2006, 05:57 AM
