Results 1 to 14 of 14
Thread: Funny Engine Noise
    vt ss 5.7 ls1
    Jun 2009
    Auckland New Zealand
    Default Funny Engine Noise
    Hi guys I have just noticed in the last few days when I am accelerating going through the gears (its an auto executive) I can here the motor almost making a "pinging" noise which makes me think it might need a tune up but the noise almost sounds metallic like and when I take my foot off the accelerator it stops and when the car is standing still and I rev it and all sounds normal, any ideas? cheers
    VZ 06 Exec
    Dec 2007
    Sydney, NSW
    VZ SENATOR
    Mar 2009
    A metallic pinging noise from your engine bay can also be caused by the exhaust heat shield bolts becoming loose and the silver cover rattling against the engine at certain speeds/RPMs etc.
    Mine rattles slightly while driving but doesn't make a noise unless I have it in gear.
    vt ss 5.7 ls1
    Jun 2009
    yeah its more a "light" metallic sound than anything to do with the gearbox so I will check the heat shields tomorrow gear changes are normally smooth., thanks
    A bicycle
    Aug 2009
    Gippsland, Victoria
    its not detonating is it? does it happen for an extended period of time if you sink the boot or does it stop after a couple of times?
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Quote Originally Posted by NonStick Squid View Post
    @old mate you drive a vs ute therefore you're a bogan therefore your point is invalid
    Exidor's Avatar
    Exidor is offline I come in peace.
    Used Martian spacecraft
    May 2008
    Earth. For now....
    vt ss 5.7 ls1
    Jun 2009
    When I floor it everthing is sweet but when it's a slow acceleration I get the noise it's not loud just weird, I was gonna try putting some 98 in it to see if higher octane changes anything and then I could rule out detonating maybe. But more liable to be heat shields I think
    VZ SENATOR
    Mar 2009
    Quote Originally Posted by Exidor View Post
    Probably heat sheilds. Get rid of 'em.
    Can you get rid of them without any problems?? I was thinking of taking them off and installing a new gasket where it bolts into the engine.
    vt ss 5.7 ls1
    Jun 2009
    Could the power steering make that noise as im driving along? Just noticed when I put the car in the garage tonight that it was making a squealing noise and checked the fluid level and it was on low, cars done 71000 km to, any ideas appreciated
    VZ SENATOR
    Mar 2009
    Power steering would not make a metallic noise. If there is air in the system from the fluid being too low, you would hear a groaning noise every time u move the wheels.
    You could test this by turning the wheels from lock to lock while the car is parked. if there's bubbles coming out your power steering has air in it....
    vt ss 5.7 ls1
    Jun 2009
    Cheers for that I think once you start hearing to many noises it's time for a bloody cold one! Merry Xmas all!
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Heat shields are there for a reason!.
    To the OP try installing non metallic washers, where the shield bolts on. That's another way to stop the noise.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    milhouse is offline Project Beast
    VZ SSZ 5.7L
    Oct 2009
    sydney
    if the power steer level is low put some nulon power steer treatment in it. it mostly stops the leaks but yet again depends on how bad the leak is for the additive is to stop it.
    the noise heat shields.
    Nobody Actually's Avatar
    Nobody Actually is offline luxo barge
    VS s2 Caprice 5l = slow
    Aug 2005
    Queensland
    since it seems to be "pinging" under load, you may want to take your mechanic for a drive and see what he/she says.
  1. funny noise??
    By vyss300kwute in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-10-2008, 05:07 PM
  2. HELP: remote make funny noise
    By wengyie in forum General
    Last Post: 12-02-2008, 05:06 PM
  3. funny noise from front
    By prjacksonau in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-10-2006, 07:45 PM
  4. funny noise
    By bradvt98 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-03-2006, 12:11 PM
  5. funny noise
    By Garth in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-03-2005, 07:57 PM
