Results 1 to 7 of 7
Thread: Heat Stroke On VZ
    the_trademarc's Avatar
    the_trademarc is offline The Cult Of Personality
    E-Series 1 Clubsport R8
    Feb 2008
    SE Melbourne, VIC
    Default Heat Stroke On VZ
    Well, not really, but the problem's at its worse in the heat.
    I posted a month or so ago about my car having a BCM Issue. Well been to the dealer and back, they found no fault, so I was like, ok, whatevs.
    Since then I've noticed that my radio and headlights only cut out when it gets a bit hot. And today, driving up to the City and back, the radio cut out like 10 times, either when winding the window down, changing gears, or sometimes when just accelerating.
    As well as this, I had the ABS Fault light come up 4 times up and back, and my temp gauge sat at half and the line before half all day.
    This only happens when its hot....prolly a coincidence, but I wanted to know if I'm alone in this, or if its happened to anyone else, and also if anyone has any ideas on how to fix it.
    What I'm thinking now is whether it may have something to do with the Tune on my car, and whether that's throwing the ABS fault warning randomly or what not.
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Did the issue happen before u had the tune?
    It could be a small as a loose wire somewhere!
    My car is always parked outside, so on hot days it cops the full force of the heat. Ive never had any electrical issues at all on hot days.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    I think you need a new battery.
    The ABS/SRS warnings are famous for coming on when the battery voltage is low, and hot weather will affect the output of the battery.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    Feb 2008
    SE Melbourne, VIC
    Quote Originally Posted by PaulSV6 View Post
    Yeah it only started to happen after the tune, and when I accidentally left my lights on at the shops and needed to jump it to get it started.
    I got the dealerships to check the wiring and earthing, but they didnt find anything, neither did I when I checked too.
    I'm not sure if its the coincidence with the heat, but it seems to happen a lot more in the heat.
    Feb 2008
    SE Melbourne, VIC
    Quote Originally Posted by danja View Post
    That could explain it. Battery's nearly 4 years old, never been changed.
    I might take get it tested at work today see what they say.
    FYI. The battery voltage on my system menu is at 12.4 before start, and then 14.2 after starting. I always thought that was what you would expect the battery voltage to be at.
    Exidor's Avatar
    Exidor is offline I come in peace.
    Used Martian spacecraft
    May 2008
    Earth. For now....
    Feb 2008
    SE Melbourne, VIC
    But even if I test the battery, that wouldnt explain why my radio still intermittently turns off? The wiring's been checked and all that, and it doesnt seem to fix the problem.
    Does anyone know any electrical experts that can help, outside of Holden? Or would Phreddy have an idea or two about it? (I'm seeing him early Feb, to get my lights done...2 years after I first enquired!!! Can't wait)
  1. [VIC] 30 CC 2 Stroke RC Car
    By tr3nt in forum Parts And Other Items For Sale
    Last Post: 24-03-2009, 09:47 AM
  2. cam or stroke?
    By vt_on_20s in forum V8 Development and Modification
    Last Post: 12-12-2008, 11:54 PM
  3. 2 Stroke or 4 Stroke
    By 6 shooter in forum The Pub
    Last Post: 10-10-2008, 03:59 PM
  4. Stroke my V6
    By sobvngrpa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-10-2005, 04:52 PM
