my vz ss has something wrong with the cluster it has lines through it and cant be read properly and ideas on how to fix it cheers, brad
I think you need to configure SSL on your web server to configure the cluser with lucci. However I would recommend to edit /etc/cluster/cluster.conf manually.
I'm with ya.
I think what is trying to be said is that the cluster needs to be hooked up to a computer at the dealership to check whether the secure sockets layer (thus SSL) is still working properly, or whether it needs to be flashed.
Can you see the lines through the screen, or is it only on the text/numbers?
Take it to Holdden & get them to plug it into there Tech2, to see what errors/faults come up!
The Blue One
