Check Power Train warning appeared. Car starts and runs ok. Just started to run and idle rough but comes good again after a few minutes. Took it to Holden and I received these error codes....
P0443 present fault
P0206 not present fault
P2229 not present fault
The present fault is an Evaporative emission control system purge solenoid circuit malfunction.
The P0206 error is an Injector 6 control malfunction
The P2229 error is a Barometric pressure sensor voltage high
Can anyone expand on this? Like the location of the purge solenoid? and so on....
Holden wanted at least 3 more hours and 250 bucks to tell me more. I said I will be back.
Thanks for your help.
