Results 1 to 17 of 17
Thread: Water pump failure after changing rad cap
    vt ss 5.7 ls1
    Jun 2009
    Auckland New Zealand
    Question Water pump failure after changing rad cap
    Hey Everyone how many of you have had your water pump crap out on you after changing your radiator cap? Seems to be common occurance, I changed radiator cap recently and now I'm getting a squeal from water pump, anyone else had similar?
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    i was just after the cap was replaced but not anymore.
    the pump is covered under my warranty anyway
    Chev badges are an instant fail
    VZ 06 Exec
    Dec 2007
    Sydney, NSW
    vt ss 5.7 ls1
    Jun 2009
    Yeah the car has only done 70 000km pretty poor design if it craps out by then
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    my water pump does the occasional squeal......... i've taken my cap off once or twice. i think mines probably on the way out but who knows........ seems ok to me.
    Mine will squeal after u've just some hard driving, pulled up quick and shut the car off........ the heatsoak after the cars off seems to stuff it a bit.....
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    VZ 06 Exec
    Dec 2007
    Sydney, NSW
    Quote Originally Posted by bigdaddycool View Post
    Who knows? A person with mechanical knowledge would know! You obviously have no idea.
    vz sv6
    Oct 2009
    Default water pump
    Mines going advised to replace hope it wont cost to much tits or tyres cost you money????????
    VZ SV6
    Oct 2008
    Newcastle NSW
    my radiator cap failed resulting in overheating engine, i replaced it then couple of months later the water pump also failed, this is common as the cooling system (or any system, auto trans etc) is only as good as its weakest part.
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    genuine waterpump from holden are 200-400 (cant remember), autobarn has them for $80, but theyre aftermarket
    Spoken by a true member of The Committee
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    I had the same issue, replaced rad cap, then water pump failured bout 2 weeks later. Got a gen one from a insider, $110.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    Sep 2008
    I think it fails because when you replace it you should probably redo your coolant and ensure you get all the air bubbles out.........
    tommySV6Ute Guest
    Did you happen to change the thermostat as well as the radiator cap? Surely just changing the cap would not introduce that much air into the system?
    jetboy's Avatar
    jetboy is offline You learn til u die
    VT exec
    Feb 2010
    Gold Coast QLD
    yep threw a new cap on a VS two weeks later the water pump shat itself
    At 43 a wealth of info , but still heaps to learn
    VZ SV6
    Nov 2010
    North shore NSW
    I heard that CPC caps (probably the most common aftermarket replacement brand for caps) have been well known to completely fail, including their fuel filler caps. IMHO genuine all the way, god knows what this cheap sh*t is doing to your car.
  15. #15
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    I think this is just one of those placebo things, i really doubt replacing or even removing a radiator cap would 'give u air bubbles' considering the oxygen in water to begin with. Im guessing that the problem with the water pump is causing an issue with the radiator cap and you lads are looking at it back to front..
    I replaced my coolant cap with one from Repco, possibly CPC after the genuine one shit itself and my water pump is fine 50,000km later... Cap also only cost me $1 due to a sale at repco, so i bought 2 of them... one is in the shed incase it was shit
    Life starts at 200km/h
  16. #16
    May 2009
    Gold Coast
    yea my guess is that the water pump is fudged to begin with, which blows the cap, replace the cap and it blows the pump
  17. #17
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    the vz cooling system is very good BUT
    its only as good as its weakest point so
    wasnt holding pressure before cap change and fitted cap then likely it may start leaking under higher pressure
    OR you fitted too higher pressure cap
    OR you spilled coolant on the belt and now the small amount the pulleys are missaligned is causing belt noise
    which is more likely as these pumps themselves dont normally get noisy they just leak from the shaft on the pump
    SO take your belt off and spin the pump and see if its noisy or doesnt spin smoothly, if bad replace
    if pump doesnt have white stain dripping down on the metal under it and its not rooted then
    personally i would take belt off and wipe it down clean with a solvent like degreaser also clean the pulleys with degreaser then FIT THE BELT ON THE OTHER WAY AROUND
    if this gets rid of your noise get another belt and likely the power steering pump needs to be aligned take it too holden for this or GOOD workshop
    with a laser aligning tool for the pulleys
    hope this helps man!~
  1. Changing water pump VN/VP/VR
    By Morton in forum Holden Commodore How-To's
    Last Post: 24-06-2011, 11:19 AM
  2. VN Fuel Pump Failure?
    By midnightinaus in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-10-2005, 11:29 PM
  3. Changing out vs water pump
    By fezza10101 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-07-2005, 11:29 AM
  4. Urgent- changing water pump...
    By comtim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-05-2005, 05:46 PM
  5. Changing water pump...
    By checks202 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-03-2005, 10:49 PM
