Results 1 to 5 of 5
Thread: vz crewman towbar wiring
    vz crewman
    Oct 2009
    Default vz crewman towbar wiring
    Hi, just fitted up a holden towbar to my 07 crewman,
    everything lined up perfectly all threads were in the body already and all holes were drilled,
    had to drop the rear muffler to fit it but thats o.k.
    My question is before l tackle the wiring for the plug , since the wiring loom is not visable
    (without removing the rear bumber) Do l have to cut in & splice into the origonal wiring?or would there be a plug behind the bumper that l can axcess?
    ive removed the inner metal panel for a look ,the one that gains axcess to the rear lights
    l could cut into that and join the wiring up there but thought some one here might have the blurb on this ...???????
    Thanks.....
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    I suggest that you don't cut any wires but use snap connectors. They are readily available from any auto parts store. Enable cables to be connected to another without cutting any wires etc. That's all most tow bar installers use when fitting trailer plugs. You only need to gain access to one of the tail lights and all connections are made there. If you don't feel competent, go see an auto electrician to be on the safe side.
    vz crewman
    Oct 2009
    o.k. good stuff, l can do the snap connector thing no probs..
    thanks for your reply.....
    vx berlina seriesII , vz storm crewman
    Mar 2008
    Question vz crewman towbar
    do you have any pics of the fitting of the towbar as i have a vu/vz/vy ute genuine holden towbar but cant see how it should fit on my crewy, it has 2 bolts and fitting plate on the left and 3 and fitting plate on the right, thanks rich
    VZ Crewman Cross6
    Jan 2010
    Let me know what you blokes need. My VZ Crewman has a towbar (assume the wiring is ok) and am happy to take pics of fittings and wiring if it helps.
    Cheers, Paul.
  1. Towbar wiring harness?
    By mxb in forum VE Holden Commodore (2006 - ?)
    Last Post: 03-11-2011, 03:27 PM
  2. Wiring diagram For Crewman.
    By NukeOZ in forum Electrical Wiring / Questions
    Last Post: 04-10-2009, 03:50 PM
  3. [SA] vs towbar/wiring
    By ab56452001 in forum Swap / Wanted to Buy / Trade
    Last Post: 26-06-2009, 11:48 PM
  4. VY Exec vs VY Crewman Wiring
    By smyth in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-09-2008, 07:15 PM
  5. towbar wiring harness
    By gottavecalaisv in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-02-2007, 08:15 PM
