Results 1 to 20 of 20
Thread: Cruise control not turning on
    VZ SV6, VL (Speedway)
    Mar 2005
    Penrith, NSW
    Default Cruise control not turning on
    Hi guys, long time lurker, picked up a VZ SV6 (auto) a couple of days ago and have some problems with the cruise control.
    When pressing the on/off button, nothing happens. Nothing comes up on the dash, fiddling with the set and reset switches does nothing either. Have tried it multiple times 10/20/30 mins into a trip after many applications of the brakes, and my brake lights are working as they should.
    I've never had a car with cruise before, so I've got no idea. Any suggestions as to what it might be?
    Thanks.
    VZ SV6 && 180sx
    Mar 2008
    Mar 2005
    Penrith, NSW
    Yep, tried it at 50, 60, 80 etc and still wont even turn on
    My parents picked up an SVZ at the same time and I've tried the same method in both cars, the SVZ works fine but doing the same thing in mine just doesn't work
    Mar 2005
    Penrith, NSW
    And also, it's not just that it wont activate, I can't get it to turn on in the first place..
    -scyth-'s Avatar
    -scyth- is offline Im alright its the others
    VZ Wagon 05
    Nov 2008
    the_trademarc's Avatar
    the_trademarc is offline The Cult Of Personality
    E-Series 1 Clubsport R8
    Feb 2008
    SE Melbourne, VIC
    Yeah sounds like the button's not working. Did you buy it from a dealership? If so, isnt there a 48 hour period where you can return a car if it is not in the condition it was advertised as?
    VY s m5 supercharged
    Aug 2008
    Mar 2005
    Penrith, NSW
    Yea got it from a dealership, have the standard 3 month warrany, he just wasn't keen on fixing small things so I can see having to fight it.
    How hard it it to pull apart the stalk and have a look at the button, or give it to a sparky?
    I did check the fuse (although not before I posted this, doh) and it's fine. It says it's the same fuse for the mirrors anyway and they were working fine.
    Cheers for the help guys
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    you gotta remove the airbag and wheel to get to the stalk, so if your not confident, i'd give it to a sparky
    Chev badges are an instant fail
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    fisrt step, check all of your brake light globes. if any of them dont work, it wont engage, as it uses the brake circuit as a safety cut off feature.
    Mar 2005
    Penrith, NSW
    Yep brake lights are all fine. I had another go yesterday and somehow managed to get it to turn on, but then wouldn't activate, and then the button wouldn't work to turn it off again. So I'm fairly confident there's something wrong with the stalk
    VZ Executive
    Aug 2009
    06vzcalais is offline Donating Member
    Aug 2009
    had this problem theres a sensor behind the brake pedal for the cruise that the dealership who replaced my brake pedal forgot to hook back up...but in your case it does sound like the stalk and your probably best to take it back to the dealer to get them to fix it if the wreck it while fixing it they have to fix it, you break it you fix it...
    Feb 2008
    SE Melbourne, VIC
    Quote Originally Posted by toey View Post
    haha, better than not turning OFF!
    LOL! Stupid Ford's
    Best take it to a mechanic. Could be anything really.
  15. #15
    VZ Crewman Cross6
    Jan 2010
    Hey Danny, how did you go with your cruise control problem?
    I've got pretty much the same problem on my VZ Crewman. Checked the fuse = ok, checked the brake lights = ok, haven't found the switch under the brake pedal yet.
    Cheers, Paul.
  16. #16
    Mar 2005
    Penrith, NSW
    Quote Originally Posted by PaulP38A View Post
    Cheers, Paul.
    I'm fairly confident that it's the stalk, but haven't looked into it yet. It works every now and then (sometimes first time, sometimes I have to press it a few times) - so yea I'm thinking it's the buttons
    Btw, if the brake lights are fine, then the brake pedal switch is working
  17. #17
    VZ Crewman Cross6
    Jan 2010
    ok, thanks mate. I'm suspecting a problem with the switch/button too.
    I've only had the ute for a few days and don't like my chances of getting the dealer to fix it, although I can always ask.
  18. #18
    VZ Storm
    Sep 2008
    I have been having a similar problem with my VZ Storm. The cruise control will work to start then when you deactivate it for slower cars (god damn them) it wont re activate...
    Though i have devised a cunning idea, as i found when i turned the car off and back on it WORKED!!! buggered if i know how to fix it but that seems to work for a while ....
  19. #19
    StealthCalais Guest
    I have the same issue with mine - wouldnt even turn on... But eventually after fiddling around with it for a while I discovered it only turned on when you pushed the indicator down (so as to indicate right) and then pushed the button. Its clearly a wiring defect or something with mine, have to get it sorted at some stage... but give it a try anyway, it might work.
  20. #20
    bloodyricho's Avatar
    bloodyricho is offline Bloody Richo
    Vr V6 Equipe (hare) and VE SV6 (tortise)
    Dec 2009
    littleton nsw
    the stalks stuff up on all commie models thats where the wreckers keep em on the shelves. geta new one or some times drowning them in contact cleaner works but only till next time lol. get a new one. ever want to now what stuffs up on a car go to a wreckers and see what they shelf for that model.
  1. VR Climate Control Not Turning On...
    By Chirpstr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-04-2012, 10:06 PM
  2. VX S2 HBD Lumina Cruise Control Turning Off Issue
    By $inisterinc in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-09-2011, 08:48 PM
  3. Man conversion-cruise control, will the auto cruise control work on manual conversion
    By pjdm1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2009, 12:25 PM
  4. vs climate control keeps turning on and off
    By nicky335 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-02-2009, 02:04 PM
  5. climate control not turning on, help
    By elljay in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-04-2006, 11:19 AM
