Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: 'OK' to drive?
    VZ Executive
    Aug 2009
    Default 'OK' to drive?
    When you start the engine, it waits a while and does its checks and if everything is good, it will display 'OK'.
    Just wondering if it does the car any harm to put it in drive and start driving before the 'OK' comes up?
    SSZ 5.7LTR & 01 VX V6 Supercharged
    Aug 2009
    Toowoomba
    For the sake of a few more seconds is it really worth NOT waiting, I even let mine idle for a few minutes till I can hear the drop down in RPM's.
    I liken it to a home PC, what happens when you try to use programs before all software etc..has loaded up? its sluggish till it catchs up with its own systems checks. I may be way off in my thinking but with an investment like you 've made why risk it.
    JMO anyway.
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Nah I never wait for the ok in my VY, just start and go!!
    VS L67 Statesman
    Oct 2006
    Melbourne, VIC
    Quote Originally Posted by D_BLOCK View Post
    JMO anyway.
    You don't need to let modern engines idle for a few minutes before driving. Just drive them normally and don't give them a hard time for the first 10 min. Letting them idle is probably doing more harm then good...
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    Aug 2009
    Toowoomba
    Quote Originally Posted by Thomas1 View Post
    Explain how its doing more harm than good when its circulating oil gently via idle revs through an otherwise dry top end, than if I was to "start and go" ?
    VS L67 Statesman
    Oct 2006
    Melbourne, VIC
    Most engines have lower oil pressure at idle so wouldn't you want to up the oil pressure and get that oil moving around quicker?
    the_trademarc's Avatar
    the_trademarc is offline The Cult Of Personality
    E-Series 1 Clubsport R8
    Feb 2008
    SE Melbourne, VIC
    Yeah I'm normally off before it comes up. It eventually does, but if I'm already over 20km it just skips the menu and goes straight to the speedo.
    It's still doing the check behind the scenes so to speak, and it will chuck up an error if there is one so you can just pull over.
    And modern cars need only 3-4 minutes of high gear-low rev driving to warm up, generally it takes my engine about 5 minutes at the most to warm up.
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Quote Originally Posted by VYMAD View Post
    Exactly y wait, the engine warms up much faster moving than if ur stationary!
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    Dec 2009
    If you have a good quality oil then the top of the motor has as much oil on it after about 5 seconds as it would ever get.
    VP Calais 3.8L
    Jan 2006
    Ringwood, Vic
    I've heard it's also better to not let it warm up as it doesn't heat up the tranny/box and it's best to let things heat up evenly.
    So i've heard anyway.
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    You don't have to wait.
    Idling for 5min (or whatever) is just burning fuel and won't save your engine at all.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    VZ Berlina
    Apr 2006
    Quote Originally Posted by impulsive View Post
    the owners manual also says not to let it warm up.
    i got the owners manual in front of me. where does it say not to warm it up?
    VZ Berlina
  15. #15
    Escape-The-Fate's Avatar
    Escape-The-Fate is offline HSV, i just want one
    VE SS, M6
    Nov 2008
    Gold Coast
    i start and go, 4:30 in the morning im not sitting around waiting for a car to warm up..plus its finished its checks by the time i get out and do the gate at the bottom of my driveway...and the revs drop off by the time ive closed the gate and down the end of my driveway..
  16. #16
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    Quote Originally Posted by HSVenforcer View Post
    It's in there. Can't remember what section though. But i've definatly seen it.
    As for the OK, yes it's alright, just make sure you dont loose traction while it's doing the checks, that can set off errors during it's checks depending on what check it's up to. If this is the case your traction and power/economy modes get stuck locked in. You must turn your car off and turn it back on to get it right. So wait the 10 or so seconds, then go?
  17. #17
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    It's safe to drive off......... as it's in special cold tables for the cams (restricting power). Generally I let mine warm up of a morning til it drops to the 600rpm range before I go........ still takes about another 10mins or so for the warm cam table to kick in......... so I know it'd be pointless dragging anyone til the car is properly running off the normal cam settings.
    But yes.... safe to drive off. I let mine warm up purely cause it's tweaked to the hilt and I dont drive it light..... so keeps the car happy and surviving. - Never let it warm up tho when leaving from work ........ gotta get away from there
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
  18. #18
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    each to their own
    the only thin the manul says is Page 4-3
    "Do not subject the engine to high load conditions such as full throttle acceleration or high speeds until it has completely warmed up otherwise you may cause premature wear or engine damage"
    ... but thats NOT the question here
    Personally I wait those few seconds anyway, by the time I've cranked, grabbed my sunnies, connected the Ipod, chose a song and got comfortable in the seat - its all checked and OK anyway. I also believe at that time the oil pressure, especially to the timing chains, are low thus why you get that rattle on cold startup so a few seconds of letting the engine pressurerise itself wont really be hurting it.
    I drive all of 3 minutes in 50kay zones with a wait at a red traffic light 9 times out of 10, then straight onto the 110Kph freeway so really my car HASN'T had adequate time to warm up completely before giving it a hammering onto the freeway.
    But yeh each to their own really I think this can be a circular debate.
  19. #19
    VE SS, M6
    Nov 2008
    Gold Coast
    im the same..5 minutes drive through suburbia and then straight onto the highway..if there was a problem im sure the car would let me know
  20. #20
    VZ SV6
    Sep 2009
    Wingham, Mid North Coast, NSW
    omg who cares, just drive the car if it has problem it will say so if not keep going, wat a silly idea of a thread
    When in the chicken coup, if i wanna get lucky, i get clucky clucky
  21. #21
    Aug 2009
    Toowoomba
    Quote Originally Posted by Chickenboi999 View Post
    If its so silly chicken little why respond?
    The OP started the thread because he wasnt sure if it would **** his car or not, legitimite question I say, as opposed to the " it will let you know if theres a problem" school you subscribe to.
    By the time there is a problem, it usually costs you.
  22. #22
    2006 VZ commodore Acclaim
    Jan 2007
    Ipswich QLD :(
    I normaly just wait till OK come up and then I leave, its only a couple of seconds of my life.
  23. #23
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Quote Originally Posted by -**wHiStLe**- View Post
    If you have an automatic, the fluid is passed throuogh the trans cooler at the base of the radiator. As the radiator warms so does the trans fluid. That's what it's always important if fitting a trans oil cooler to make sure you don't by-pass the one at the base of the radiator. Can cause problems with engine not warming correctly.
    As for waiting for the check lights to go out, if you start the engine when you first get in, put your seat belt on, check there's nothing behind or in front in that time the lights are probably out. No harm to drive with them on, so long as you haven't got a problem.
  24. #24
    VzVzVz's Avatar
    VzVzVz is offline <<< My Ride
    VZ S ute
    Jun 2009
    Port Melbourne
    I put into 1st and drive off as soon as it fires. Not when it's cold of course.
  25. #25
    VzVzVz's Avatar
    VZ S ute
    Jun 2009
    Port Melbourne
    It says allowing the engine to idle for an extended period of time upon start up is unecessary and wastes fuel.
  1. To all Member That Don't Drive A Commodore, What Do You Drive:
    By Evolution_Ends_Here in forum The Pub
    Last Post: 07-12-2008, 05:40 PM
  2. what drive "D" do u guys drive in
    By plAythiNG in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-08-2008, 09:45 AM
  3. to drive or not to drive- shredded cable
    By [JUDGE] in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2007, 05:16 PM
  4. How much did u pay for your VE drive-away?
    By boleh in forum VE Holden Commodore (2006 - ?)
    Last Post: 27-09-2006, 12:24 AM
  5. wat (D) do i drive in
    By craigillz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-04-2005, 01:06 AM
