Results 1 to 14 of 14
Thread: VZ Speedo calibration issue
    VZ Berlina
    Apr 2006
    Default VZ Speedo calibration issue
    Hi all i have a VZ Berlina (V6) and recently noticed that when my speedo says 100km/h i am really only doing about 95km/h. 110km/h = 105km/h etc. Is there a way to calibrate the speedo without taking it somewhere?
    The car has VE Stato rims on it and when i asked about calibration i was told it was all ok.
    I heard somewhere (more than likely this site) that there is somewhere in the settings to change tyre size etc. I just wanna check to see if the right size has been programmed in. I found the adjustment for the odo but nothing for tyre size.
    Any help appreciated
    cheers
    steve
    EDIT: am running 235/40R18 tyres
    VZ Berlina
    2004 VZ Calais 190Kw
    Dec 2009
    Penrith NSW
    By changing your profile you've altered the running circumference making the error worse.
    I had a lower profile tyres given to me that I put on my 17" Calais standard rims and when the speedo was reading 100km/h the GPS showed 96. Replaced those tires with the standard profile Potenza Adrenalins and now 100km/h on the speedo registers 100-101 on the GPS. Very happy.
    P.S. In the menu screen you can adjust the odometer reading but NOT the speedometer.
    VZ Berlina
    Apr 2006
    so basically the dealer did a shit job of things by not calibrating the speedo properly?
    i guess that is a pretty obvious answer.
    thanks for the info
    VZ Berlina
    the_trademarc's Avatar
    the_trademarc is offline The Cult Of Personality
    E-Series 1 Clubsport R8
    Feb 2008
    SE Melbourne, VIC
    Quote Originally Posted by Trent L View Post
    How do you do that?????
    Feb 2008
    SE Melbourne, VIC
    Quote Originally Posted by HSVenforcer View Post
    thanks for the info
    And yes, having low profiles and bigger rims can and will chuck out your speedo, as will having it Tuned. There is a lot of controversy surrounding that with speeding fines. I know people who have successfully used that as their defence to get off a fine.
    As for me, I know mine's 3km/h out, and my analogue is 5km/h out. So just need to factor it in whilst driving. I don't think its worth taking it to Holden and re-calibrating.
    -scyth-'s Avatar
    -scyth- is offline Im alright its the others
    VZ Wagon 05
    Nov 2008
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    Im curious about the odo reading adjustment via the menu without VDO tools ...
    2004 VZ S-Pack Ute
    Jan 2009
    Gladstone QLD
    Mate i would suggest taking it to Ultra Tune for the calibration on the Tech2 gear. My local shop is brilliant! I havnt had them do anything mechanical for me but for Tech2 work they are cheap, quick and know what they are doing!
    Also i hate my local holden, bunch of wankers! Over charge and no clue! They said 150 to clear an SRS fault where as Ultra Tune did for 20 bucks!
    Hope that helps.
    Dec 2009
    Penrith NSW
    With regards to my comment about adusting the odometer - see PDF attachment from the VZ Owner's Handbook..
    Apparently, the menu for 'Enter Calibration Adjustment' only relates to the 'triple-window' dash cluster as fitted in Calais & the like. That allows you to adjust distance calibration and fuel calibration.
    Attached Files Attached Files
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    ^^^He's right.
    I remember reading this in my WL user guide. I got it when i had the WL cluster installed.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    Torquative's Avatar
    Jun 2005
    PaulSV6's Avatar
    Jun 2008
    Castle Hill
    Yep sure is!
    The Blue One
    Quoted for truth
    PaulSV6's Avatar
    Jun 2008
    Castle Hill
    Yep sure is!
    Ive been meaning to do the fuel calibration. Just havent got around to doing it!
    The Blue One
    Quoted for truth
    VZ Berlina
    Apr 2006
    thanks for teh responses. much appreciated!!!!
    VZ Berlina
  1. Calibration of speedo
    By H.I.M666 in forum Electrical Wiring / Questions
    Last Post: 31-05-2009, 03:56 PM
  2. speedo calibration
    By one_and_only2004 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-05-2009, 12:49 AM
  3. speedo calibration
    By 2wild4u in forum Holden Commodore How-To's
    Last Post: 05-10-2008, 03:59 PM
  4. speedo calibration
    By shumway in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-02-2007, 08:19 PM
  5. Speedo Re-calibration
    By ozute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2005, 07:57 AM
