Results 1 to 10 of 10
Thread: Coolant change SV6
    VZ SV6 3.6 A5
    Dec 2005
    SEQ
    Default Coolant change SV6
    Hi,
    I have a Sept 04 build SV6 and noticed my coolant is due for replacement about 6 months ago. Does anyone know the drainage plugs in the engine block which can be removed to flush out the old coolant. Does the thermostat have to be removed or any other bits and pieces? Any proven procedure would be very helpful. Thanks
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Take your car to a cooling professional. They have cleverly designed equipment that connects to your cooling system (whilst still in the car) that will purge the system of old coolant and replace it with (your choice) of suitable replacement. You won't even need to get your hands dirty. A more efficient way of doing it than trying at home without suitable equipment. Good luck with it.
    VZ SV6 3.6 A5
    Dec 2005
    SEQ
    Quote Originally Posted by Benboy View Post
    Thanks for the advice Benboy
    Took it to the Holden dealer and got the "good" coolant. Must admit it was a lot easier this way.
    VZ Evec 05
    Jan 2010
    South Coast NSW
    i did mine myself. emptied it and then filled it with a funnel while the engine was running runs perfect. did it about 40,000km ago and everything is perfect. changed the radiator cap in the process too and no problem
    VZ SV6 3.6 A5
    Dec 2005
    SEQ
    Quote Originally Posted by marcdon View Post
    To satisfy my curiosity, are there water jacket drain bungs in the crankcase of the Alloytech?
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Quote Originally Posted by diysv6 View Post
    How much they charge you?
    This is wat i did over a year ago. No overheating issue's to date. If you have the know how ten go do it.
    Not 100% sure where the drain plug on the engine is but the one i opened was at the bottom of the radiator. After that i just ran the hose through it until i saw clear water coming out.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    and thats all I do before track days, skidpan etc except going off the workshop instructions which are slightly different, but esentially the same.
    Although it doesnt hurt to have it flushed properly because you cant really do much at home by yourself except drain the coolant from the tank and radiator
    VZ SV6 3.6 A5
    Dec 2005
    SEQ
    Quote Originally Posted by PaulSV6 View Post
    Hi PaulSV6
    The dealer came out all up $125. The coolant was about $65. With the Brizzie weather around the 30+ lately, it was very convenient to pass the job on.
    PaulSV6's Avatar
    Jun 2008
    Castle Hill
    Yeah thats not to bad, when i did mine only cost me $35 for the coolant thats using Castrol long life coolant.
    The Blue One
    Quoted for truth
    VZ Evec 05
    Jan 2010
    South Coast NSW
    um as far as i know i dont think so....but i dont know much haha.
    i simply ran nulon radiator flush through the system and then drained it out of the bottom hose. reverse flushed the radiator and then hooked everything up and refilled it with nulon long life red coolant.
  1. Coolant change
    By dans_vz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-08-2010, 07:22 PM
  2. How Do i Change The Coolant
    By MY-42-VT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-10-2009, 06:18 PM
  3. Vy coolant change
    By snow67 in forum Just Commodores Polls
    Last Post: 16-05-2009, 12:20 AM
  4. coolant change.
    By mrVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2007, 04:32 PM
  5. Coolant Change
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-12-2005, 09:39 AM
