Results 1 to 14 of 14
Thread: 5spd Auto - Oil and Filter
    VZ SV6, VL (Speedway)
    Mar 2005
    Penrith, NSW
    Default 5spd Auto - Oil and Filter
    Just at work doing the 150,000km service on my 5spd auto SV6. Pulled the sump off the auto and am a little confused.
    First off, is the oil for the 5 spd auto just Dextron III? From what I've read/been told it is, but the oil I've drained out of the box is dark brown, and very thin. In fact I can't tell what it is, doesn't look or smell like anything familiar
    And is the Gearbox filter different between the 4spd and 5spd? The filter I've been given looks completely different to the one in the box, so I'm thinking I might have been given the filter for the 4spd.. But then again I've never seen one before so I might not know what I'm looking at
    Thanks
    2011 voodoo thunder ss
    Jan 2009
    hi mate, yeah the fluid is dexron III however they have now upgraded to dexron vI (6) and its a much better fluid and is completely compatible with the old 3, its what i put in when i did mine about 6 months ago, also the filter is different between the 5 speed and 4 speed, so if its different, chances are its the wrong one
    Mar 2005
    Penrith, NSW
    Thanks mate, I'm guessing the brown oil was just flogged out auto oil - in which case I certainly wont be waiting another 150,000kms to change it again. I can't believe how much smoother and tighter the auto is now
    Just put Dex 3 in it, but will have a look at the 6 later on down the track
    And yep, had the 4 speed filter. All sorted now, glad to finally have it all done
    06vzcalais is offline Donating Member
    Aug 2009
    Quote Originally Posted by Danny40 View Post
    was the change relitively easy and non time consuming as my autos just come onto 120 000 and its never been changed my gf and i drive prety hard so wouldnt mind changing it
    VZ Evec 05
    Jan 2010
    South Coast NSW
    I change mine every 80 000 as a rule of thumb. pretty easy. hardest part i reckon is filling it up again
    Mar 2005
    Penrith, NSW
    Was pretty easy, especially having access to a workshop
    Filler/drain plugs are torx bits, but the drain plug is useless - will never get all of the fluid out without dropping the sump, which needs to come out for the filter anyway. Is just 20 10mm bolts for the sump and it drops straight off, then the filter just slips out - then reverse to put it back together.
    Would get a little difficult filling it up without a pump
    And yea, after today, there's no way I would leave it that long to change it.
    Also noticed that the gearbox sump has a filtermag in it, great idea
    VZ SV6
    Jul 2008
    any one know of any how - to's on how to change the 5 speed fluid with diagrams and pictures ?
    VZ LX6 Adventra
    Aug 2009
    Quote Originally Posted by allanssv6 View Post
    that would be very handy as i wouldnt mind doin mine and putting new boost valve in as well while im there. Had a quote for it and was around the 350 mark so if i can do it myself and save some money
    2005 VZ SV6
    Jun 2009
    Australian Crapital Territory
    Bit of a thread dig here, but will I need a sump gasket when I remove the sump?
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    2005 VZ SV6
    Jun 2009
    Righto. The bloke there said that there was two different kits for the 5sp? I thought only the 4 and 5 speeds were different.. Anyone know about this? It's an 05 sv6 btw..
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    yea the dude prob didnt know what he was on. he prob meant 2 different kits for the vz...
    Spoken by a true member of The Committee
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    2005 VZ SV6
    Jun 2009
    Roger, thanks for the help guys
  1. i swapped my vs auto for a vl 5spd
    By holdenfan86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-12-2009, 03:06 PM
  2. 5spd auto quick shift
    By impulsesv6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 17-08-2009, 10:55 PM
  3. I have a 5spd auto
    By jakewaze in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-03-2009, 12:00 AM
  4. vz sv6 5spd auto
    By ssvy in forum VY - VZ - WK - WL - V2
    Last Post: 17-04-2007, 02:35 PM
  5. Auto to 5spd conversion V6
    By Brocky_05 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-10-2005, 12:01 PM
