Guys, had to change the BCM on my 06 SVZ. Got the radio code from a local Holden dealer but when it's entered the error message appears and then it locks out for an hour. Any thoughts as to what the problem is? Cheers
Maybe you need the code for the car the BCM came out of?
I suffer from Dyslexia and bad gramma. Now it's your turn.
The BCM has the radio pin stored in it, when the BCM is replaced the PIN needs to be programmed into it, whoever fitted it should do this as a matter of course, they would have had to link it anyway.
Rob
