G'Day all...
Just wondering if anyone had an Idea how to change the fogloght globes in a VZ SV6. Kinda want to know what I'm in for before I start pulling the bumper off.....
I just love the way other motorists on the highway think it's an unmarked cop car.........
And Yes, it is a manual
Well your halfway there, once u get the bar off. Im pretty sure the foglight housing is kept in place by 2 or 3 bolts. Undo these then the housing comes out.
Not sure on the rest but if u give me about an hour ill give u the info.
The Blue One
You should be able to get the foglights out without pulling the front bar off. I was able to put them in my vz S ute (same kit as sv6) without touching the front bar
Chuck Norris destroyed the periodic table, because he only recognizes the element of surprise
Disregard my first post:
As f1tzy said above the bulbs can be accessed from the front.
Remove fusible link F102
Remove the screw at the top centre of the lens
Rotate the clamp ring clockwise until the retaining hook is at the 9 o'clock position, then remove the clamp.
Pull the lens & reflector assy from the fog lamp housing
Disconnect the bulb lead from the harness connector
The Blue One
Thanks guys!
Where is fusible link F102? In the fusebox or the regulator box?
Fuse/Relay box, left hand side of engine bay. Its the long blacklid![]()
The Blue One
What are the replacement bulbs for the fog lights, as i want to buy some before i pull the old ones out, H2, H3 H..... Not sure.
Thanks in advance
H1 55W(standard).
Thanks heaps
The Blue One
Doh! I just went out and got h1's lol oh well I'll take em back and get sum h3's. Cheers pau.
Well I tried and stuffed up. My bad. It's hard to go from memory
lol, all good mate, thanks for your help any waysthey swapped them over for me as well!!
