Results 1 to 8 of 8
Thread: Whats the minimum distance on front disks?
    vy acclaim wagon
    Nov 2009
    Default Whats the minimum distance on front disks?
    My VZ is wobbling at 80Kph and when I brake its really wobbly at 60Kph.
    I have checked the front rotors with vernier calipers and they both have a distance of 28.00mm each.
    What's the minimum distance?
    I'm a toolmaker by trade.
    I Just don't want to have Holden rip me off.
    Also there's plenty of meat on the pads too
    Thanks guys.
    N/A
    Nov 2009
    try the DBA website....i *think* it's on there or maybe it's bendix....hmm.
    It should be stamped on your rotors too..
    26mm is ringing bells to me..
    www.thewheeldeal.com.au
    Ask me for a great deal on tyres & wheels shipped Australia wide.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    26mm, you can machine them down to remove the thickness variation
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    While we're on this topic........ all my brake discs are solid (dont move), apart from my front drivers...... it wobbles (u can grab it and it moves with the wheel off). Can u tighten these or is it my wheel bearing gone?
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    vy acclaim wagon
    Nov 2009
    06vzcalais is offline Donating Member
    Aug 2009
    for the price of machining you can buy new discs online, mine have been machined numerous times, i still regret it getting new slotted rotors soon. i also have a wheel wobble found out it was a buckle on the inside edge of my rim....
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by bigdaddycool View Post
    there designed to move, cause there floating discs, the rest of them arnt moving cause the rotors will have a bit of surface rust holding them on, + the pads and calipers holding it
    VZ AWD One Tonner
    Jul 2006
    VT-VZ are notorious for wobble, and it's very rarely related to the brakes, and 99% of the time float in the front hubs:
    Common Problems in Holden VT fitting TB 07
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
  1. vt v6 wagon front disks shudder
    By boomboombas in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-05-2010, 11:06 AM
  2. Minimum Wage...
    By 1991_Vn2nV in forum The Pub
    Last Post: 05-11-2007, 10:29 AM
  3. Minimum Rotor Thickness
    By Slow VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2006, 03:01 PM
  4. i need a trailer 6x4 minimum
    By TheIceman in forum Swap / Wanted to Buy / Trade
    Last Post: 25-03-2006, 04:36 PM
  5. Minimum Eyebrow Height of a VT
    By hsv2k in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-05-2005, 10:26 PM
