Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: HID headlights
    Cv8 II monaro 5.7
    Jul 2009
    Naracoorte
    Default HID headlights
    hi guys
    just looking to replace my stock headlight globes with HID's but not too sure wat wattage and type of HID to get to fit an 04 calais? im thinking 8000k. should i change the foggie colours aswel?
    the_trademarc's Avatar
    the_trademarc is offline The Cult Of Personality
    E-Series 1 Clubsport R8
    Feb 2008
    SE Melbourne, VIC
    Quote Originally Posted by marksy26 View Post
    hi guys
    I cant remember what wattage my lights were, was that long ago, was a Phillips kit. But I'd definitely recommend changing the fog globes too, because then they look like a pair of old Englishman's eyes in comparison to the whiteness of the HID's.
    I've got H3 Crystal Globes in my Fog's, not an exact match, but good enough. Supercheap Auto for 15 bucks, 20 minutes to take the front bumper off and replace the globe.
    VZ LX6 Adventra
    Aug 2009
    if looking for highest illumination then 4500K is the go if you want something whiter and bluer the 6000K and anything higher you start going towards purple tint and don't illuminate as much. You can put HID legally into ANY car as long as they have projector head lamps, so after marker high lights from VY down from memory otherwise the VZ calais and HSV models had them.
    VZ Evec 05
    Jan 2010
    South Coast NSW
    Quote Originally Posted by LxAdventra View Post
    wrong mate.
    im looking at the ADR right now.
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    Back on topic, the OP never asked if they were legal or not.....
    Personally id go 6000 as its a nice white rather than a blue
    Heres a colour chart anyway
    The Black Beauty
    VZ Storm
    Sep 2008
    are they expensive ?? and are they easy to install hahaa because as you say they look AWESOME!
    VZ SS Ute M6
    Jan 2010
    I think the Philips Crystal vision globes are enough, their not HIDs (or the sun as they are known) but they've still got that white light coming from em... I think their 4300k, but im pretty sure anything over 4000k is illegal. They are a massive improvement over the standard ones from the outside look to driving with em...
    VZ SS Ute M6
    Jan 2010
    Talking
    Quote Originally Posted by TVR-161 View Post
    I wonder how 15000K's would look as highbeams lol
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    Thread cleaned.
    Keep it on topic.
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Motor vehicles have been required to comply with Australian Design Rules
    (ADR's) for lighting since October 1991. ADR 13 mandates the number and
    position of lamp assemblies, ADR 46 prescribes the photometric requirements of
    the lamp itself and ADR 51 is the standard for filament bulbs.
    ADR 51 accepts ECE regulation 37 as an alternative standard for filament bulbs
    and prescribes the dimensional and photometric requirements for filament bulbs
    (including headlamps). This ensures inter-changeability and correct
    functioning when installed in a complying lamp unit.
    All complying bulbs sold in Australia would be marked with the "E" mark and
    possibly the words "Suitable for European Use". The packaging may also
    indicate compliance with ADR 51 or ECE 37.
    When a replacement complying bulb of the correct type (for example H4 45/60
    Watts) for a complying headlamp is fitted to that assembly, the light emitted
    will be within the spectral requirements for white light. This will not be in
    breach of Section 63 to Schedule 1 of the Transport Operations (Road Use
    Management- Vehicle Safety and Standards) Regulation 1999.
    Although these lamps are a standard fitment to many newer vehicles, a "blue"
    complying lamp can be fitted to a lamp assembly on a vehicle that was not
    originally fitted with these bulbs.
    It is important to note that ADR 51 limits the power of various bulb types,
    and bulbs of a similar style but higher power rating will not comply and
    should not be used. For example, the common H4 bulb that has a complying
    rating of 45/60 watts, is available in much higher rating of 45/100 watts. The
    higher powered bulbs produce more glare and the resulting light pattern would
    not comply with the ADR.
    Although regulations do not require drivers of pre-1991 vehicles to fit
    complying bulbs, consumers should be careful when fitting non-complying "blue"
    light bulbs to pre-ADR vehicles, as the resulting light spectrum may fall
    outside the standard for white light (that is, the blue frequencies may
    predominate).
    If a Licenced Examiner suspects that the light output from a headlight appears
    blue, the examiner should take appropriate action based on the following
    summary tables:
    For vehicles manufactured on or after 1 October 1991
    • Bulb must be marked.
    • Bulb must be the correct wattage.
    For vehicles manufactured prior to 1 October 1991
    • Bulb does not have to be marked.
    • Bulb may be alternative higher wattage.
    • Bulb must not show obvious blue light (when viewed directly ahead).
    Licenced Examiners Action:
    If, during the course of an inspection, Licenced Examiners have cause to
    inspect vehicles modified by changing the original lighting componentry
    assemblies, they are to ensure that individual vehicles comply with the
    previously mentioned details. Modifications of this type
    which do not comply with the above requirements are to be rejected
    immediately.
    Any (ANY) modification(s), unless approved to ADR standards, that change/alter/modify any aspect of your vehicle from the ADR standards/requirements that existed at the time of manufacture of your vehicle are ILLEGAL.
    VZ Evec 05
    Jan 2010
    South Coast NSW
    VZ SS Ute M6
    Jan 2010
    I see, well i still dont think it should apply to high beams on how bright they are because your not supposed to use them (to put it simply) when anyones around...
    *Sounds like whatever you do to your car is going to be illegal anyway so why try..? lol
    TVR-190's Avatar
    WK Statesman LS1
    Jun 2008
    what part of stay on topic didnt you guys understand, he wasn't asking about the legality of them or for a list of Australias ADR's....
    How often do you drive with your foggies on marksy, if always id probably get some whiter globes if only occasionally probably not worth the effort. Just get some narva +50s or phillips blue vision globes for the foggies.
    The Black Beauty
    StealthCalais Guest
    VZ Calais [Black Edition]
    Have a look at my post, when I got my HID's... got all the info on there.
    Colour temperature wise... I went 6000K, I reckon thats the perfect number! Anything lower down the spectrum (eg 5300K or whatever it is seems to be yellow still) and higher (eg 8000K and it just looks stupid and loses brightness). The photos are fairly accurate of what the colour looks like, though I'd say they have a bit more white in them in reality (as they look quite blue in the pics).
    Also... SMD LED's for the foggies are an option thats what I got. If you want them purely for looks (they dont actually light up the ground, just look good, and arnt dazzling as some fog/driving lights). Otherwise get a set of those Philips blue vision or crystal vision (or whatever they are called) to match - I might look into getting a set for the foggies.
    Hope it helps
  15. #15
    VZ Storm
    Sep 2008
    will have a look thanks and ADR's are there Traffic cops will stop you just depends on how bothered they are by it hahahaha
  16. #16
    VZ Evec 05
    Jan 2010
    South Coast NSW
    a little off topic but I just purchased a set of H1 and H4 Philips X-treme power globes and they are fantastic, the best light globe I have ever used. Low beam is bright and has a perfect cut-off line, and high beam is like having a set of spotties on the front. I bought them from
    www.powerbulbs.com
    UK company, arrived in 5 days. Guys are trying to flog them on Ebay for $63 a set. I got the two sets and a free set of parkers AND free delivery for $80.
    I know its off topic but I would say these are the cheapest way to get a great light output
  17. #17
    VZ Executive
    Aug 2009
    Really sorry if this is off topic, but I've been interested in getting HID lights for a while now, but know nothing about it (as usual), so just have a few questions.
    1. How do I install them? (I have a VZ)
    2. If I get HID for my headlights, then do I have to get an even higher watts for my high beam? Or does it all come in one pack?
  18. #18
    VZ Storm
    Sep 2008
    i think there is a post on it somewhere in the DIY section ( i can never find haha) But im sure there will be someone come in here and tell you how. im not too sure either.
    But im sure the high beams come with it as a pack
  19. #19
    StealthCalais Guest
    Quote Originally Posted by toey View Post
    1. Not sure about the executives... but theres two 'caps' on the back of my headlight housing - to enable you to get to the bulb. What I did is drill a hole through the middle of the plastic to get the cables through. You then have to connect everything up - intructiones usally come with the kit. Find a place to mount/store the ballast. Then your good to go. But this will take 40 mins to an hour.
    2. Usually the HID kit is only for one set of lights - ie you buy a kit for the low beams (H11 bulbs) If you want a set for high beams youll have to get another set - wattage and colour temp will all be the same you just need a different bulb - (H9 bulbs).
  20. #20
    [ASLYVY] is offline DavidP
    2006 VZ Executive
    May 2006
    Hoppers Crossing
    Quote Originally Posted by StealthCalais View Post
    In the case of an executive with calais/ss/hsv headlights...will buying a H4 (Hi/lo) kit solve the problem of having the parkers or main light turn off when high beam is turned on?... :S
  21. #21
    VY2 Berlina V6 wagon and Mercedes Benz E430
    May 2009
    Was pondering over this for ages. I have a VY with projectors and was going to put the Phillips Crystal vision in my car but found out they dont do it for H11s.. I ended up getting some HID's on Ebay for $50. They are 4300K and when I put them in, even they look more bluey so wouldnt go higher than that. My mate put HID's in his commodore and the cut looks bad because he doesnt have projectors...
    Best $50 I ever spent tho.
  22. #22
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    May 2009
    Yep. Its no Phillips brand but the supplier is actually from Australia otherwise I wouldnt have bought them. It was a no reserve auction but usually buy it now for $99 or something. Might have been just lucky. Ive had put them in and they are brilliant.
  24. #24
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    All imma say is blue tint = instant rice box.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
  25. #25
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Quote Originally Posted by danja View Post
    How blue though?
  1. VY Headlights
    By Mossman in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-10-2011, 11:00 AM
  2. Exec/Acclaim Headlights --> SS Headlights for $80 ...
    By nEb. in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-06-2011, 11:06 PM
  3. VZ Headlights to Projector Headlights
    By harvs01 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-09-2009, 05:27 PM
  4. Headlights
    By bush_basha in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-05-2006, 05:31 PM
  5. WTB: VX SS headlights
    By VT2VEight in forum Swap / Wanted to Buy / Trade
    Last Post: 22-05-2006, 06:54 PM
