Results 1 to 12 of 12
Thread: Difference between VZ and VE Alloytec 190
    VZ SV6
    Dec 2009
    Ballarat
    Question Difference between VZ and VE Alloytec 190
    G'Day all...
    If the VZ and VE SV6s both run the same engine (alloytec 190), and the VZ runs 190Kw, and the VE 195Kw, what's teh difference between the engines? Is it possible to get the VZ varient running at VE spec without major modification. I figured this'd have to be a very simple mod that any Holden dealership could? Just put in the VE softwear?
    I just love the way other motorists on the highway think it's an unmarked cop car.........
    And Yes, it is a manual
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    There's differences in how the tunes are setup, but u can "port" the VE gear into a VZ setup and change most axes to match......
    As for actual part differences, I'm not entirely sure...... but i'd say they are pretty similar probably. Someone else can eloborate on that.
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    vz sv6
    Jan 2010
    other than the tune setup ,the exaust is also twin to the rear unlike the vz wich could see better results
    VP Calais 3.8L
    Jan 2006
    Ringwood, Vic
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    ve spec have different timing chain setups, different cam sensors (my06 vz is the same as ve), better vvt actuators i think, not to much to see, but internally a lil bit different
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Quote Originally Posted by andyman View Post
    Not to mention, throttle calibration on the VE's is much better.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    the_trademarc's Avatar
    the_trademarc is offline The Cult Of Personality
    E-Series 1 Clubsport R8
    Feb 2008
    SE Melbourne, VIC
    Quote Originally Posted by -**wHiStLe**- View Post
    Maybe something about the SIDI?
    Or is that for VZ's aswell?
    The SIDI isnt an Alloytec engine anymore, I believe. But dont quote me on that.
    VZ SV6
    Dec 2009
    Ballarat
    The SIDI is teh same block underneath, but everything else is different; pistons, cams, heads, injectors, throttlebody etc. Inquired with Holden
    VzVzVz's Avatar
    VzVzVz is offline <<< My Ride
    VZ S ute
    Jun 2009
    Port Melbourne
    VZ SV6
    Dec 2009
    Ballarat
    For anyone curious, th eofficial Holden line is that it is 'not just one part change, but a variety of diffferences' , and they do not suggest altering the ECU.......
    Meh, Headers, cats, cold air intake, racing filter,. intake manifold insulator and a VCM tune should help..
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    So would you say your better off buying an 06 VZ than an 05 VZ to get the new setup for a grand or 2 difference ? Is there any problems with the early 04-05 versions?
    Sep 2008
    Quote Originally Posted by ruffiano View Post
    G'Day all...
    You cant use the VE software on a VZ more then likely, but whether you can copy the VE tune settings into a VZ is another story but I dont think thats possible either.
    I've found they have diff rev intervals on the VE Tune with reguards to the cams that doesn't seem to take with a VZ for some reason.
    I've tried converting the VE Omega tune to the VZ....... but the cam settings seem to cause the car to pulsate power wise when in the various new cam rev zones the vz's dont have.
    So I guess the answer is probably 'no'. Just get the car tuned.
  1. Alloytec to vn
    By MALMODIFIED in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-11-2009, 10:18 PM
  2. Difference between 175 and 190 kw alloytec
    By Verds in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-05-2009, 12:59 PM
  3. Gas On Alloytec 190
    By CNULTR in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-10-2006, 11:51 PM
  4. Alloytec into VT?
    By denizengt in forum V6 Development And Modification
    Last Post: 11-05-2006, 03:52 PM
  5. Alloytec and Alloytec 190 Engine Specs and Details
    By Gobbles in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-06-2005, 05:24 PM
