Page 1 of 2 12 LastLast
Results 1 to 25 of 46
Thread: Alloytec 'tapping' whats your opinion
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Default Alloytec 'tapping' whats your opinion
    Basically, As a result of minimml oil (im guessing) the motor has picked up a nasty tapping noise coming from the front middle of the motor and increase with the revs. Car has done 105,000 km and is due for a service.
    There are a few things i have been led towards.
    1) The water pump is on the blink
    2) Fingered Cam shaft
    3) Bearing or something similiar
    I will endevour to post a video up of the tapping..
    Life starts at 200km/h
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    VZ 3.6
    Feb 2009
    North of Adelaide
    tapping noise as you put the motor under load? heavy acceleration?
    "And i gave that man directions, even though i didn't even know the way; because thats the kinda guy i am today "
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    alot of earlier even upto early ve's get a few light tapping noises around the motor, alot of it comes from valves, might gets a bit of a tap from a timing chain
    its all part and parcel of motors getting really really quiet these days, you hear every little noise,
    thats obviously depending on what your regarding as a tap?
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    it sounds like a tap EVERY revolution of the motor.. and increases with the revs.. tap a spanner against a hammer lightly and thats the sound
    06vzcalais is offline Donating Member
    Aug 2009
    i get a tapping sound from mine also always have sounds simular to the injector tick on a RB30
    HoldrodeoLT's Avatar
    HoldrodeoLT is offline I have no lemon pledge...
    2004 Holden Rodeo RA LT, 2008 Polaris Hawkeye 300
    Aug 2008
    How long did you run on low oil?
    You may have run a channel in one of your rod bearing inserts, this causes the pistons to move a small amount at the big end, making it "knock"..
    There made of aluminium and wear easy if pistons arnt lubricated enough.
    About as handy as tits on a bull
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Arrow
    Here is a short video link, hopefully you can hear the tapping noise
    YouTube - DSCF7800.AVI
    have been told it is cam related or the buckets
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    ah i remeber something like this from a while ago, its really rare, but remove the valve covers and see if a lifter has fallen off....
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    yea will do about to start now.. hopefully it is fixable without too much of a dent in the pocket
    impulsesv6's Avatar
    A quick Alloytec
    Dec 2006
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    cover is off on the drivers side, the sound is definately there.. SOMEWHERE..
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
  15. #15
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    hard to see in the pic, is all the lifters in the right spot, one hasnt fallen out? if you get a bar/ratchet and socket youll need 1/2 to get the leverage, turn the motor clockwise and see if you can here the sound?
  16. #16
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    or if you remove the starter relay and work out which pin is number 30 and which one is 87 off the diagram on the side of the relay, you can short that and it will crank the motor, see if you can hear where its comming from there
  17. #17
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    lol maybe u should come do that !! haha nah i turned the motor, i can def hear it coming from the rear of the inlet cam, and maybe center of the exhaust cam.. bit hard to tell to be honest
  18. #18
    impulsesv6's Avatar
    A quick Alloytec
    Dec 2006
    he can hear the sound when rotating the engine by hand... its coming from the intake cam from the rear...
    edit... haha remind me to bring the stethescope round on friday
  19. #19
    impulsesv6's Avatar
    A quick Alloytec
    Dec 2006
  20. #20
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    hopefully i can diagnose the problem and have it fixed as soon as possible, i might be looking at a loan tommorow..
  21. #21
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    did big daddy cool tune your car by any chance haha, maybe because of the extreme amount of cam timing work he does, or did he remove your serpentine belt and advance the timing on the pulleys?............
  22. #22
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    sussed out a bit further.. with the ears of my partner it apparently is coming from the front of the inlet cam.. and has several taps in several places
  23. #23
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    id suspect vvt actuator possibly then, is there any fault codes up?
  24. #24
    Aug 2009
    Quote Originally Posted by impulsive View Post
    nothing like i imagined sorry for missleading info
  25. #25
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by 06vzcalais View Post
    All good mate (Y) hopefully i have it sussed tommorow, have a mechanic coming for a look. If not should be sorted by friday (hopefully). If it can not be pinned by then it will be in the workshop and getting fixed.
    Might be looking at a few different things while its off the road.. Stay tuned!
  1. Whats your opinion?
    By akust0m in forum General
    Last Post: 27-08-2009, 06:36 PM
  2. Is SUMMERNATS Slowly Dying - Whats Your Opinion
    By VNCalais3800 in forum The Pub
    Last Post: 22-06-2009, 08:32 PM
  3. Whats your opinion on this?
    By VL_5SPEED in forum General
    Last Post: 25-07-2008, 09:06 PM
  4. Whats your opinion
    By executive_power in forum The Pub
    Last Post: 20-08-2006, 10:56 PM
  5. Tapping from alloytec 190 motor
    By Walks_SV6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-05-2006, 03:03 PM
