Results 1 to 7 of 7
Thread: Location of thermostat housing on alloytec SV6 engine
    VZ SV6 3.6 A5
    Dec 2005
    SEQ
    Default Location of thermostat housing on alloytec SV6 engine
    Can anyone give me the specific location of the thermostat housing on the rear of the alloytec motor?
    Is it bolted to the inlet manifold assembly or is it bolted on the engine block under the inlet manifold?
    I am thinking of replacing the spark plugs and wondering if the thermostat comes away with the inlet manifold. Looking at another thread, the spark plugs on the right hand bank are accessed after removal of the inlet manifold. Wondering if I can kill two birds with one big rock.
    Any pictures of the area available or comments on the idea?
    HoldrodeoLT's Avatar
    HoldrodeoLT is offline I have no lemon pledge...
    2004 Holden Rodeo RA LT, 2008 Polaris Hawkeye 300
    Aug 2008
    Quote Originally Posted by diysv6 View Post
    Apprently its under the inlet manifold and you have to "sqeeze" your hand down the firewall to access it.. dont quote me on this.. never owned an alloytec.
    About as handy as tits on a bull
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    on the back of the motor just offset to the drivers side, if you remove the inlet manifold, its relativly easy to get to once you move a couple things out of the way
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    VZ SV6 3.6 A5
    Dec 2005
    SEQ
    Thanks everyone for your help. I have continued trawling the VZ threads and have another question. There is a thread where the spark plug replacement is documented. I am happy with the removal of the "upper intake manifold assembly' (GM Speak) aka plenum in some publications. Has the the lower section of the inlet manifold any coolant passages? I had a read of the Haynes Manual #41743, in Section 2B-7, 'Plenum and Inlet Manifold - removal and refitting'.
    It goes about describing the process and finishes up at paragraph 18 stating to "Check the coolant level, adding as necessary................".
    Is there any coolant released when the lower intake manifold is removed?
    Thanks
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    nope (13 characters)
    2004 holden VZ v6 ute.
    Feb 2011
    Bathurst
    Default vz v6 thermostat location
    Just some pictures I was sent to show the Holden vz v6's thermostat location.
    Attached Thumbnails Attached Thumbnails Location of thermostat housing on alloytec SV6 engine-s7303925-small-.jpg   Location of thermostat housing on alloytec SV6 engine-vz-v6.jpg
  1. VX Supercharged 6 Thermostat housing
    By DOOM in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-12-2009, 10:07 AM
  2. Thermostat Housing
    By OSL-060 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-03-2009, 07:58 PM
  3. leaking v8 thermostat housing vs/2
    By vs hay hauler in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2008, 01:20 AM
  4. Thermostat Housing.
    By eXcon in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-05-2008, 06:54 PM
  5. thermostat housing
    By 90VN55 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-09-2006, 09:26 PM
