Results 1 to 10 of 10
Thread: possible cost to fit harrop truetrac
    6lt VZ Clubsport
    Aug 2009
    Default possible cost to fit harrop truetrac
    vz clubsport diff not locking, looking to fit harrop truetrac. Or is there any alternative to harrop?. Thanks.
    VX HSV GTS
    Apr 2006
    Tas
    There is a Kaaz but they are around the same price.
    I got a quote to fit a Truetrac to my car with new bearings and it was going to be $600
    I think Luke from WPS was quoting about $900
    These pricing are for installation only.
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    kaaz is a couple of hundred cheaper, well it was when i was looking into upgrading my centre. search 'kaaz' there is a thread where people are comparing the kaaz centre to a shimmed up standard lsd centre. a few people swore by the tightened up standard lsd.
    myself, i got the kaaz and cant fault it, its great
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    wikky is offline ............
    VZ SSZ
    Mar 2008
    Here
    Quote Originally Posted by thumper View Post
    Another option is the Eaton Truetrac. Same internals as the Harrop, just not a billet housing. The Harrop is rated at 500rwkw and the Eaton 500rwhp (372rwkw). From memory the Eaton is about $500-$600 cheaper than the Harrop. Unless you're pushing big power/torque, I'd save the money and go the Eaton. Just my 2c.
    VX HSV GTS
    Apr 2006
    Tas
    If you search around you can get a new genuine Harrop Truetrac for around $850-$900. Google is your friend
    6lt VZ Clubsport
    Aug 2009
    mawsy is offline giggity giggity
    VZ SSZ UTE
    May 2008
    QLD
    VX HSV GTS
    Apr 2006
    Tas
    VE R8 LS3, VYSS Ute 10.0@146MPH & VYSSTT 525rwkw
    Jun 2005
    SA
    To be completly honest guys you need to ask yourself the question, ive tested all 3 LSD types, Factory, KAAZ & the tru-trac, on street and track use.
    What ive found with the KAAZ, very predictable when sliding the car around, or burnouts, broken a few, and many people around Australia have also broken many KAAZ's as well.
    What ive found with the tru-trac is well designed for the street, ive tested one for the last 2 drag meetings and its coming out, both meetings the car wouldnt hook up, and would just wheel spin the entire track, overall result was 3-4 tenths slower at the 1/8 mile, this is what ive found, and its due to the design of the spiral LSD setup.....
    In all honestly the factory LSD is the best by far for drag use, fastest 60ft's with a factory LSD, ive broken my fair share of rear driveline components, so do they take punishment "YES they do", however if you like to pull out of corners lighting the tyres the factory LSD isnt for you, as the cone design isnt capable of handling this type of abuse.
    VX HSV GTS
    Apr 2006
    Tas
    Nice write up.
    I have heard some different comments but I cannot give a personal opinion as I haven't installed mine yet.
    I guess the reason I went with the Harrop is it requires very little maintenance and I am only a weekend warrior on the track to have fun, so it was the best choice as a good all rounder. As my current diff (Hydratrak) is so unpredictable as to when it will spin a single or twins I needed to do something and I didn't like the feedback regarding the noise of the Kaaz (I think difference oil and regular maintenance reduces this) and I didn't want to put a stock LSD so that made my choice easier.
    I'll let people know how it goes when I get mine installed.
  1. [VIC] Eaton truetrac for 28 spline BW
    By chargedvx6 in forum Parts And Other Items For Sale
    Last Post: 08-08-2009, 11:45 PM
  2. [SA] FS: Harrop Manifold & TB
    By inocnt vn in forum Parts And Other Items For Sale
    Last Post: 26-07-2009, 04:31 PM
  3. [SA] EOI: Harrop Manifold
    By Snakes-Calais in forum Parts And Other Items For Sale
    Last Post: 25-03-2009, 07:29 PM
  4. LS1 Harrop Intake
    By Jesterarts in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-09-2007, 11:14 AM
  5. harrop brakes
    By bensta in forum General
    Last Post: 09-08-2005, 09:41 AM
