Results 1 to 5 of 5
Thread: will an sv6 steering wheel with paddles (active select) fit an executive??
    SKNOT9 is offline All hope is gone
    VS series II Acclaim
    Feb 2007
    Lobethal, South Australia
    Exclamation will an sv6 steering wheel with paddles (active select) fit an executive??
    As title states, Any help would be greatly appreciated.
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    the steering wheel should fit, but you should pull the paddle off seeing as they wont work.
    the wheel is basically the same, the paddles just screw onto the wheel
    Chev badges are an instant fail
    Feb 2007
    i was just wodering if the connection to the steering wheel was any different seeing as it needs extra cables for the paddles.
    ashbox's Avatar
    VZ SS 6 Spd
    Apr 2007
    The Car
    you'll be fine with the swap, just put your steering wheel controls onto the new wheel.
    the plug will only be different if you keep the controls and the paddles on the wheel
    Feb 2007
    thanks mate
  1. VE SSV Transmission - Reprogramming to mod Active Select?
    By RustyCardores in forum VE Holden Commodore (2006 - ?)
    Last Post: 08-10-2009, 12:13 PM
  2. How's the Active Select?
    By PhantomSV6 in forum VE Holden Commodore (2006 - ?)
    Last Post: 07-05-2009, 07:17 AM
  3. active select auto issue with my sv6
    By mmrdb in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-01-2009, 09:36 PM
  4. Active Select acting up (i think)
    By brownie82 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-01-2007, 05:03 PM
  5. VZ Adventra Active Select
    By AWD_VZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-11-2005, 09:41 PM
