Results 1 to 15 of 15
Thread: VZ 2005 Executive Overheating
    VZ Commodore
    Feb 2010
    Default VZ 2005 Executive Overheating
    My 2005 VZ Execuitive has overheated twice in the in the last month. Seems to be fine until i get caught in a bit of traffic and the gauge starts wondering up. I have noticed the coolant level going down a bit over the last few weeks then completely forgot about it and it overheated last night. I cant see any leaks, is it most likely the Thermostat? Im a bit strapped for cash at the moment im hoping its easy and cheap to fix?
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    replace the radiator/motor cap, they are only cheap, normally the rubber seal on the expand and the crimped spring seperates, thats generally the first thing that goes on them
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    the_trademarc's Avatar
    the_trademarc is offline The Cult Of Personality
    E-Series 1 Clubsport R8
    Feb 2008
    SE Melbourne, VIC
    The radiator cap is 20 bucks from Holden, and that fixes the problem if you've picked it up early. If you let it go for longer you might have water pump troubles as well.
    VZ Executive
    Mar 2008
    I've had a similar thing to this too just recently on my 2005 VZ. The temperature gauge stays firmly on a hair above the 1/4 mark as long as I stay on the motorway. What's weird is at 60-70km/h it climbs gradually, then within about 20 seconds of hitting the onramp (100-110km/h) the gauge literally drops from the limit down to the 1/4 mark in about 10 seconds flat.
    Also I've discovered that the temperature gauge stays under control at the 60-70 speed if I limit the auto gearbox from changing too much ([2] at the lights then into [3] when I've hit cruising speed).
    The only symptom I have found is that the fan is getting a good workout when the gauge has been high, at no stage have I found any leaks or signs of leakage in the engine bay. Although I'm an amateur at knowing where to look ...
    I have just now checked the coolant level and it's hard to tell - I thought it normally had a green colour but the coolant dipstick has no sign of green on it, just clear but to the right level. Also I tried taking off the radiator cap and it looks kind of dry in there... turned the engine on with that cap off and didn't see anything running through there which has got me worried and feeling a bit stupid now. Is it a simple case of coolant's gone and I'm putting water pump on death row? What seems strange about it is the way the gauge drops to normal as soon as I hit 100...
    VZ lumina Executive
    Jan 2009
    qld
    Same thing happened with me today.
    No leakage at all.
    Car temp normal at 60 -70 speed
    climbing hill temp gone up to 80% near red area
    took the car to mechanic he reckons radiator needs service.
    Booked the car for wen.
    Azkatro if you find anything let me know.
    SBM
    SBM is offline
    VS 5Spd
    Aug 2010
    Streaky Bay
    VZ lumina Executive
    Jan 2009
    qld
    VZ lumina Executive
    Jan 2009
    qld
    I did noticed when I started the car the temp gauge went to 20% and fans didn't kicked off. So will that be thermostat ?
    VZ Calais Alloytec 190
    May 2011
    NSW
    I had a similar problem. Kmart auto simply let the radiator bleed all the air out and they thought that in the last service when they flushed the system they didnt take out all the air an a air bubble was causing the problem. They also topped up the fluids. A pressure test showed no signs of leaks etc After all that and now 3 months after still no issues
    VZ lumina Executive
    Jan 2009
    qld
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    not again.... if over heats when in traffic and fans work (can hear) and resevoir level slowly getting lower...
    you have a leak and an air lock in the sytem because of it..
    air locking is a common problem in these motors
    another complaint i hear is it overheats with a/c off but not when a/c on
    when its cold engine off
    take cap of radiator and fill with water till stops bubbling
    if you have a bleed screw top rhf of radiator loosen it
    top up again until water comes out screw
    LIGHTLY NIP UP SCREW (they break easy if overtighten)
    refit cap
    overfill resevoir (too top)
    take r/h and l/h engine cover off
    get a bright torch
    run car at idle till top radiator hose feels tighter or temp gauge is at half (either or)
    now look for leaks common ones below
    with torch check 2 heater hoses at firewall (rhr of motor) all the way to their metal fitting on motor (heater tap or hose fittings/clamps)
    with torch look down rear of motor lh and rh near where motor meets the transmisson and look for white or coolant coloured stains (thermostat)
    at front of motor middle pulley is water pump look for stains or wet under it AND above it on the front of the motor ABOVE the crankshaft pulley (biggest one) (water pump and coolant outlet o-rings)
    last look under radiator (below it) for drips or stains
    when you find the leak ring up and get a qoute to fix it in the meantime
    do this from above when cold before you drive it to extend the life of the engine
    no gaurentee you wont kill it though this would be the minimum if my car was overheating
    also drive with a/c on heater on hottest setting and fan speed 2 this will drop engine temp a little bit more.
    refit cap
    VZ lumina Executive
    Jan 2009
    qld
    there is no sign of leak.Funny thing is that it only started happening after I got my Transmission serviced. Mechanic said it could be just coincidence.
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    if after doing all that i said up there it still over heats and no leaks that i listed in common places....
    the uncommon places are the heater core (inside car wet carpet near middle of dash at floorpan)
    auto cooler inside radiator (milky coolant OR auto fluid) check dipstick of auto for milk
    head gaskets or cracked cylinder heads (milky oil or coolant)
    i will bet one of the common things is leaking or its air locked but, check again....
    if its only happened since the auto fluid was done thats suspicious.....
    if they were a little ruff and they might have taken an auto cooler line off to flush the auto
    they may have cracked the auto cooler or the radiator where it bolts into the tank (on the radiator)..... i would check for milk in auto fluid and for leaks on the plastic tanks on the radiator paying attention to where the metal hoses come out of the tank....
    VZ lumina Executive
    Jan 2009
    qld
    I am from sunny coast also db_notso . If you know any good reliable mechanic , Please let me know. Thanks for all the help
  15. #15
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    i could give ya a hand to diagnose it i guess pm me what area you live in if its close i could stop in, gonna cost you a beer~!
  1. My First Car - 2005 VZ SV6
    By BullittSV6 in forum VY - VZ - WK - WL - V2
    Last Post: 01-05-2011, 11:32 PM
  2. 2005 VZ EXECUTIVE - SSV 19's
    By Royal VZ in forum VY - VZ - WK - WL - V2
    Last Post: 22-03-2010, 06:03 PM
  3. V6 VR Executive overheating and tried everything
    By Played in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2008, 10:40 AM
  4. 2005 VZ Executive Stereo Questions
    By Paytz in forum Car Audio
    Last Post: 25-09-2008, 11:24 AM
  5. Cold Air Induction for 2005 175 Executive
    By Crabito in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-12-2007, 07:54 PM
