Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: Towbar wont fit
    Tuttle's Avatar
    Tuttle is offline stupidity reigns supreme!
    VZ Acclaim
    Feb 2009
    Default Towbar wont fit
    I have just tried to install a 2100 kg towbar. i got the first part on that sits behind the rear bumper but the part that sits underthe fuel tank i cant bolt on.
    Its a holden sedan towbar off a vy and im trying to bolt it on a vz
    the problem is that there is no bolt hole on the passangers sude for the extra heavy duty part.
    where does it bolt?
    if anyone can give me a pic of this that would be great
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You have to bolt it to the bit that is on the car then drill up through the boot. You should have a plate that fits up inside the boot as a brace.
    Visit my Facebook page
    Tuttle's Avatar
    VZ Acclaim
    Feb 2009
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    drills in through to the spare tyre well
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Tuttle's Avatar
    VZ Acclaim
    Feb 2009
    wow must pop up right at the very back. Do i have to remove the muffler. We are talking about the section that sits further forward on the car, front side of the fuel tank
    VZ Executive
    Dec 2008
    You shouldn't have to remove the muffler but if it makes it easier to bolt it might be a good idea to remove it! When I took my towbar off to clean the under carage of my VZ Sedan it was bolted under the boot and around the tank and muffler but the set up on a wagon might be different! Have fun it's a frustrating job lol!
    Couldn't be without my Commodore
    Tuttle's Avatar
    VZ Acclaim
    Feb 2009
    this is the section that im having trouble getting in. this is how the towbar goes in if standing at the back of the car.
    i know how to connect it to the other section of towbar (under the rear bumper).
    the two vertical braces, i can find the bolt for the right side but not the LEFT.
    The other pic is the parts that the guy gave to me when i got it (being as its second hand), he isnt sure if these are off this towbar or another one.
    If any one has a pic of how this all goes on that would be great
    Attached Thumbnails Attached Thumbnails Towbar wont fit-13022010115.jpg   Towbar wont fit-13022010116.jpg
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Take it to a tow bar installer and have the job done so that it will be safe. The last thing you want is your trailer/van detaching and careering off into oncoming traffic and resulting in multiple deaths/injuries plus much expense for you (if job is not done satisfatrily).
    Tuttle's Avatar
    VZ Acclaim
    Feb 2009
    its only a few bolts to put in, i really dont want to pay someone $150 just to tighten bolts.
    If there is welding or drilling then maybe i will depending on where it needs to be done, otherwise i can do it just need a pic of where it goes
    Tuttle's Avatar
    VZ Acclaim
    Feb 2009
    can anyone post a pic of the brack in the boot for the heavy duty towbar. that would be great
    Tuttle's Avatar
    VZ Acclaim
    Feb 2009
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    With the towbar up against the car, the two brackets that sit against the body brace in front of the tank, you have to drill through into the boot.
    Tuttle's Avatar
    VZ Acclaim
    Feb 2009
    Quote Originally Posted by Not_An_Abba_Fan View Post
    yeh mate i got that one cheers. its the section that extends to the font of the car under the fuel tank. i cant find where it bolts towards the front of the car (in front of the fuel tank)
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Isn't that what I said?, the section the goes up in front of the tank.
  15. #15
    Tuttle's Avatar
    VZ Acclaim
    Feb 2009
    sorry my bad. its just that the towbar hits the sub frame where it is meant to bolt. Am i meant to drill into this?
  16. #16
    VZ Exec Wagon 2007 3.6L
    Sep 2008
    Broken Hill NSW
    can u take a picture of what is blocking the tow bar's mounting hole to the body/floor of the vehicle?
  17. #17
    Tuttle's Avatar
    VZ Acclaim
    Feb 2009
    Quote Originally Posted by holdenvtman1123 View Post
    Sure can, will do it tonight.
  18. #18
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    From the way you are describing it, yes, you drill through that into the boot. But I will wait until I see the pictures before I say a definite yes.
  19. #19
    Tuttle's Avatar
    VZ Acclaim
    Feb 2009
    its taken me ages to find time to get under my car. Here is the pic of the towbar section that hugs the tank.
    The photo shows the part that extends upwards on the front side of the fuel tank and near the muffler.
    The bolt hole you can see will not line up with the hole in the towbar.
    there is also a gap between the towbar and the frame.
    does anyone know how this bolts on or does anyone have a pic of their towbar
    Attached Thumbnails Attached Thumbnails Towbar wont fit-25022010117.jpg   Towbar wont fit-25022010120.jpg
  20. #20
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I think the V8 and the V6 bars are different. The bars are the same from VY-VZ so that won't be your issue, but they have to be the same engine. EG if it is off a VY V6, it won't fit the VZ V8, and vise versa. The only other thing it could be is that it is bent. Are there any cracks in the paint that look as though the bar has been bent?
  21. #21
    Tuttle's Avatar
    VZ Acclaim
    Feb 2009
    I dont think it is bent.
    I would imagine that the holes on the frame would have a nut welded on the inside, otherwise how am i meant to get a nut in there to bolt it. I found a VY SS in the car park down the road that had a heavy duty and he just left that side unbolted??
    Going to holdens tomorrow see if they can help with how its meant to bolt (dont like my chances with them tho)
    Its almost like im missing a bracket
    Thanks for your help anyway.
  22. #22
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You have to drill right through to the boot, a long bolt with a crush tube is used.
  23. #23
    Tuttle's Avatar
    VZ Acclaim
    Feb 2009
    oh, wow. im surprised it goes through to the boot casue its a long way forward
  24. #24
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You will find that it comes through the raised section just behind the rear seat.
    That is the way the Hayman Reese heavy duty towbar fits up anyway.
  25. #25
    bloodyricho's Avatar
    bloodyricho is offline Bloody Richo
    Vr V6 Equipe (hare) and VE SV6 (tortise)
    Dec 2009
    littleton nsw
    if you look under the sound deadening (black tar stuff) inside the boot about where the holes line up underneath there will be dimples where you should drill.
    Making and running DUAL CHIPPED ECU SINCE 2010
LinkBacks (?)
  1. towbar
    By ab56452001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-04-2009, 03:34 PM
  2. VL towbar fit on my VN??
    By Mordred in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-04-2009, 04:10 AM
  3. vy towbar
    By gottavecalaisv in forum VY Holden Commodore (2002 - 2004)
    Last Post: 31-01-2007, 03:33 PM
  4. VX towbar, will a ute towbar fit a wagon???
    By Phrog in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-01-2006, 03:31 PM
  5. VT towbar
    By scojohara in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-11-2005, 03:31 PM
