Results 1 to 20 of 20
Thread: hard to turn the key
    az_sv6's Avatar
    az_sv6 is offline coudnt aford a v8
    vz sv6
    Sep 2009
    western sydney
    Question hard to turn the key
    had a problem with my ignition the other day.
    dont no if it was the heat (coz it was a stinking hot day) but i couldnt turn the key!
    i finaly got there after mucking around with it for an half an hour.
    had any1 else had this prob?
    svsex is offline big blue
    190 sv6
    Jun 2008
    did u check if it was the steering lock, wiggle the steering wheel a little bit then turn the key?
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Nup, car has started first time everytime on hot days. As mentioned was the steering lock on?
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    Berlina
    Oct 2009
    vk.jonno's Avatar
    vk.jonno is offline :):):)
    Vk commodore, hq one tonner, hj ute,
    Nov 2009
    south east
    steering lock for sure
    Quote Originally Posted by BIGbrown1 View Post
    Hey dea, financed my VS 3yrz ago, desper8 4a car, meter read 214,016kms... I PAID $14,000.00, 3yrz l8r im dealin with alot of problemz... n e cheap BUT good mechanix in west melbourne? n e info appreci8d... Fanx...
    Quote Originally Posted by Menace38L View Post
    yea if i end up getting it il lay low from the cops lol jus want it for skids etc lol
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    I had the same problem yesterday.
    Wasnt the steering lock at all.
    Key just wouldnt turn.
    Took the key out and put it back in and away i went.
    VZ SV6
    Aug 2008
    had a simular prob and rang holden they advise me the barrel had to be replaced, so i used gentle persuasion (forced it) and no problem since.
    az_sv6's Avatar
    vz sv6
    Sep 2009
    western sydney
    yeah wasnt the steering lock.
    just keepet pressure on turning the key and moved it in and out.
    thought i was going to brake the key off.
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    could be the ignition barrel going faulty not picking up the security code on the key? pot guess on just knowing how the security works in the execs.
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    VZ Executive
    Mar 2008
    I had this last year on a hot day. Couldn't turn it, wasn't steering lock and didn't want to force it too hard. NRMA bloke came out and just turned it with a bit more force than I was using. He said it was common on them (late model Commodores) in the heat.
    az_sv6's Avatar
    vz sv6
    Sep 2009
    western sydney
    cant see how the heat affects it. but its something i can live with it. ill just think of it as an immobiliser.
    91 vn s
    Jun 2009
    Adelaide, SA
    i rekon it could just be a faulty or worn or stupid sticky ignition barrel, mine does this quite often, all i do is pull out the key and reinsert and away we go. Only happens if i turn off the car and need to turn on again (such as at the petty station).
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Quote Originally Posted by az_sv6 View Post
    Heat affected ignition lock is a very common fault mostly in European built/designed vehicles. Lock manufacturers often use plastic components in the locks, the heat causes the plastic to soften and deform. Any half decent auto locksmith can rebuilt these locks using components that are not heat affected.
    VY Calais Supercharged
    Feb 2010
    yeah mine did the exact same thing eairly last year. it ended up having the barrol replaced had to get RACQ out to get it goin they where goin a tow it but ended up geting it going befor the towie got there.
  15. #15
    VZ SV6
    Aug 2008
    not heat affecting the barrels this all the "bling" hanging of the end of the ignition key
  16. #16
    az_sv6's Avatar
    vz sv6
    Sep 2009
    western sydney
    Quote Originally Posted by baracuda View Post
    iv already done that once before in my 1st car, i had a serious amount of "bling" on my other keys now iv only got 2 other keys on this ring.
  17. #17
    VZ Calais MY06
    Nov 2006
    Canberra, ACT
    I had this exact problem the other day during the heat. It was a prick. Bloody thing would not turn. I forced it so hard I thought I was going to break the key and it finally turned with a clunk. Took me a good 10 minutes of trying. It was like the steering lock wasn't fully releasing. It was a bit dodgy the next few times after that as well. Hasn't been bad the last few days.
  18. #18
    May 2008
    we've had this problem before.my wife couldnt budge it.got towed to a friends workshop.he says wear and tear causes a ridge inside the barrel.after forcing it loose he cleaned it up with a die grinder and its been smooth as silk since.
  19. #19
    az_sv6's Avatar
    vz sv6
    Sep 2009
    western sydney
    just put it on the on going list of problems with commodores, or what i like to call it the never ending story XD
  20. #20
    VZ Calais (Alloytec 190)
    Jan 2010
    Suva, Fiji
    ohh the 'bloody key wont turn!' saga. I just had my car replaced with a aftermarket ignition barrel! it has been 3 weeks in waiting..!!
  1. Installing hard top, hard lid or hard cover?
    By clapnrobem in forum General
    Last Post: 12-10-2011, 08:36 PM
  2. Key won't turn?
    By tristan2355 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2011, 08:08 PM
  3. VE Full Map/ Turn by Turn SatNav question
    By Boeing737 in forum VE Holden Commodore (2006 - ?)
    Last Post: 10-05-2007, 10:53 AM
  4. power steering to hard to turn
    By bigjas in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-10-2006, 06:23 AM
  5. Problem with amp turn on/turn off
    By don80 in forum Car Audio
    Last Post: 05-06-2005, 08:06 PM
