Results 1 to 11 of 11
Thread: Overheating Issue - Coolant reserve leak?
    VZ SV6
    Oct 2009
    Default Overheating Issue - Coolant reserve leak?
    Hey all last week for the first time since i've owned the car (05 SV6) the temp gauge went right up and a warning sound came on. Pulled over let it cool and went right back down again and never had another issue. Forgot about it to be honest.
    Almost happened again yesterday - temp went up but I stopped the car before it reached the red. Checked the coolant reserve and noticed it was pretty much empty so I started to fill it up only for it all to pretty much just spill out down under the car directly under it.
    Question is - since I haven't had a chance to have a proper look at it (and I'm not mechanical savvy at all) - what would cause the water to spill out like that? Is there a hose under there that might have come loose? Would the reserve itself be cracked? Something much worse?
    I opened the radiator cap as well and noticed (obviously I would assume) that it was a little low so i topped it up straight into there as well for now until I can get it looked at properly.
    Cheers.
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Theres a possibility there could be a crack in the reverse tank.
    On the radiator cap, did u check the rubber ring? These can fail.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    the_trademarc's Avatar
    the_trademarc is offline The Cult Of Personality
    E-Series 1 Clubsport R8
    Feb 2008
    SE Melbourne, VIC
    Quote Originally Posted by PaulSV6 View Post
    *Correction* These WILL fail. Around 60k generally.
    Radiator Capr would be the first place to start. If it was pouring out from underneath it could be a crack in the tank, and also the water pump could have eaten itself up and causing a leak to. But I guess if it didnt piss out when you filled up the radiator its more likely the coolant res tank.
    VZ SV6
    Oct 2009
    Thanks guys for the responses - much appreciated.
    I checked the cap and it seemed ok to me - but I'll get that replaced anyway just in case. I'm thinking this probably isn't the cause of the leak though because as you said trademarc - it's only spilling from the reserve tank directly under it.
    Does anyone know if it is common or known for this to crack or water to spill from this area?
    Where is the water pump located?
    Thanks again all and sorry for the questions - I dont have a chance to get it looked at until the weekend so any help now would be appreciated.
    VZ Calais
    Jul 2009
    mine has been getting a bit warm the last few days and it seems as though about 1L of coolant was missing - funny since i had it changed in october... since refilling to the top its been sweet
    MY10 VE SV6
    Sep 2004
    Blue Mountains, NSW
    Quote Originally Posted by the_trademarc View Post
    Yep I had mine replaced at 50,000km, and then again at 120,000km. Both times the car boiled on a warm day with no prior indication of issues. Mine never leaked from around the cap area - it spills into the reserve tank, filling it, forcing the water out. When the car cools it sucks back into the engine from the reserve tank, and the only indication is the reserve tank low. Basically it's not the rubber that fails - it's the pressure relief built into the cap that opens early, relieveing pressure & thus water, earlier than designed
    Ride: MY10 VE SV6, Poison Ivy, White LED Footwell and boot lighting, JBL GTO608C front speakers, JBL 6*9 rears, JBL 4 chan amp and low level outs in the head unit
    Custom Plates
    vz acclaim
    Oct 2009
    just wondering as i have only had the vz for 4 months had no cooling problems and still don't guage always sits at 1/4.
    My question is the reserve tank is always about half or full but when opening the radiator cap i don't see any coolant at all. should i see coolant?
    i did top up and it only took just over half a litre untill it was at the cap.
    j-mo is offline busted head
    VE V
    Mar 2010
    Bulldog Edd is offline Banned
    VZ SV6
    Feb 2012
    whats the best way to check if the reserve is cracked or not because the exact same thing happened to me yesterday, I put coolant in the reserve and it just poured out quickly? Are there any hoses that could of come lose as well or is it a crack?
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Did you check the level in the reserve first or just add water?
    Silver Certified.
    VZ SV6
    Feb 2012
    It was bone dry, then a started to add the water but as soon as it was going in it leaked out quickly
  1. VR Overheating, leaking coolant from engine?
    By Radar in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-09-2008, 03:10 AM
  2. Oil in Coolant Reserve
    By TigerVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-01-2007, 07:45 PM
  3. Coolant stuck in reserve tank
    Last Post: 29-09-2006, 10:15 PM
  4. Help, overheating, drinking coolant
    By JTW008 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2006, 11:18 PM
  5. VS Overheating - coolant leaks
    By HsvMan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-01-2005, 09:00 AM
