Page 1 of 2 12 LastLast
Results 1 to 25 of 41
Thread: VZ Auto 'Power Shift'
    VZ Wagon 9C1
    Feb 2010
    Dora Creek, NSW
    Question VZ Auto 'Power Shift'
    Hi all,
    Glad to be able to legitimately join, having just taken possession of a VZ Wagon 9C1 spec, plus a few other little bits and pieces.
    In the center console there is button labelled 'PWR' which brings up a 'PWR Shift' dialogue on the dash display. I can't seem to find any information on what changes this makes.
    Can someone enlighten me? Will get some pics up ASAP.
    Braden
    06vzcalais is offline Donating Member
    Aug 2009
    all it does is moves the shift point further up the rev range
    eg it will normally shift at 2800 press power it will now shift at 3200 (example only guys)
    VZ Wagon 9C1
    Feb 2010
    Dora Creek, NSW
    Thanks! It is as I suspected
    Anyone have any figures on its impact on economy?
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    it also adjusts the auto clutch release/apply zones..... so u'll use more fuel most of the time even if u drive slow with pwr mode on..... cause it's designed for u to drive faster
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    VZ Wagon 9C1
    Feb 2010
    Dora Creek, NSW
    So in other words, the clutch is more aggressive between shifts? Meaning quicker shifts along with shift points higher up the rev range? Sounds fun...
    Thanks people!
    Aug 2009
    Quote Originally Posted by zvagon View Post
    Thanks people!
    dont drive around all the time with it on thou id suggest only using it when pulling up hills or towing, but its your car you drive it how you want
    VZ Wagon 9C1
    Feb 2010
    Dora Creek, NSW
    Aug 2009
    Wouldn't think of it, I am as much in favour of frugality as I am fun
    just take it for a drive with it on, seriously there isnt much of a difference
    VZ Berlina
    Jan 2010
    Caringbah, Sydney
    As said its just the shift points and read somehwere on here ages ago it is only effective up until 80% throttle. After that both modes will be the same.
    I use it when towing my boat, good to hold it for a second instead of changing up then dropping back 2 seconds later.
    VZ SV6 && 180sx
    Mar 2008
    I've had mine turned on constantly for around the last 6 months and noticed no change in fuel economy...
    WTB: VZ Chasers
    Aug 2009
    Quote Originally Posted by Kal123 View Post
    just for my own frame of mind, why do you drive around with it constantly on
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    I have a VZ CV8Z Monaro & noticed it doesnt have a "Power" button at all . So I guess it was deleted. Honestly, I never used it on my VY , So I dont think it was worth having, GMH must have thought the same!!!!
    Aug 2009
    Quote Originally Posted by colgf View Post
    Wouldnt happen to be a manual would it. lol nah jjk
  15. #15
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
  16. #16
    05 VZ SV6 With VCM tune by CHE
    Mar 2009
    Also the PWR button also introduces a mode that keeps the car in a certain gear ( does not change up when you need the power) after you drive in a aggressive style on the 5 speeds auto boxes..
  17. #17
    VZ Calais MY06
    Nov 2006
    Canberra, ACT
    Does anybody know if PWR mode in combination with the paddle shifters has any effect or does manual shift override PWR?
  18. #18
    Aug 2009
    active select overrides PWR
    i stand corrected i knew something overrode the pwr button but it was only cruise control,
  19. #19
    VzVzVz's Avatar
    VzVzVz is offline <<< My Ride
    VZ S ute
    Jun 2009
    Port Melbourne
    Quote Originally Posted by bigdaddycool View Post
    Clutch? An auto transmission woks by applying pressurised fluid between a series of reduction gears. The planetary gearset on the engine side of the box controlls the take off and shift points. There is no actual clutch plate in the auto.
  20. #20
    VZ 06 Exec
    Dec 2007
    Sydney, NSW
    Quote Originally Posted by v8freak55 View Post
    The torque converter does have a lock up clutch.
  21. #21
    VZ SV6 && 180sx
    Mar 2008
    Quote Originally Posted by 06vzcalais View Post
    No reason at all, I put it on when I drove up one of our mountain ranges, and have just never bothered to switch it off.
    And I've noticed no difference when driving the car normally...
    WTB: VZ Chasers
  22. #22
    Mar 2009
    That is weird as mine clearly revs a bit higher in each gear before changing when driving carefully, it also changes down gears earlier which uses more fuel on the overrun.
  23. #23
    VZ SV6 && 180sx
    Mar 2008
    I'll take it off for the weekend, and see if i notice any difference.
    It might just be that I'm used to how it drives with PWR on...
    WTB: VZ Chasers
  24. #24
    Mar 2009
    Yeah ive never done a back to back consumption with it turned on and off. Unless you are driving in hilly areas where holding gears would be beneficial for fuel consumption it must use more if it is revving longer in each gear.
  25. #25
    Escape-The-Fate's Avatar
    Escape-The-Fate is offline HSV, i just want one
    VE SS, M6
    Nov 2008
    Gold Coast
    i use the pwr button if im on a fun bit of road, as it drops gears more willingly. I havent noticed a difference in fuel..and i usually just drop back to 3rd myself on the stick if im going up hill as the car labours abit before it decides to drop a gear itself.
    Sticking a Chev badge on any Commodore is like putting a Nissan badge on a VL
    EOI....VE SS 18" wheels x4 with 5000k's on new tread, 2 of have very minimal gutter rash (previous owner) otherwise like new send me a pm if interested.
  1. auto shift kit...?help
    By aussie_cruzin in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-03-2010, 11:28 PM
  2. VN Auto shift kit v6>8 help please.
    By K3zBang in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2009, 12:32 PM
  3. Ls1 Auto Shift Kit
    By VU-S-LS1 in forum LSx Development and Modification
    Last Post: 12-01-2007, 12:03 AM
  4. shift kit for auto
    By GeorgeB in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-07-2006, 05:40 PM
  5. Vs Auto Shift Kit
    By 64now95 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-10-2005, 07:30 PM
Tags for this Thread
