So I have recently bought a VZ Wagon which is sitting on Pedders suspension at what the owner says is '25mm' below Fe2.
I am keen to experiment with raising it back up to Fe2 standard, as I can get some cheap springs. I understand some of the difficulties in mismatching suspension hardware, but in your experience will this move work? Or is it possible the springs will be too long... given it is only 25mm?
Cheers boys.
Dont know what you're on about but stick to FE2 springs, they are great all round GMH setup for country roads.![]()
I believe it has been lowered using Pedders springs/struts to SL, or whatever the nomenclature for 25mm below Fe2 is. I would like to raise it back up using Fe2 springs.
Just confirming there will be no issue with a longer spring on the strut.
New to the VZ bandWAGON...
ill buy your sl springs!
