Well my car is getting the plugs and injectors done on friday and i just wanted to know if the intake manifold has a special gasket?
yeah they have a gasket, try and get a ve one cos its metal instead of the ususal cork stuff, or if you can hold off, order a set of mace insulators.
Chev badges are an instant fail
cheers bro. How much do the mace insulators cost, also what kind of power increase do they give?
The Blue One
Thats no prob, u can always take the manifold off again & fit the spacers .
The Blue One
holden should of replaced it with a reusable gasket. havent heard anything over the top about the insulators so i havent tried them but cant see a whole lot of difference in peformance
Life starts at 200km/h
Also what spark plugs are you guys using, Platinum or iridium?
The major problem with the factory gasket is that it can tear easily when taking the intake manifold off - sometimes half will stick to the engine and half the intake, causing it to rip when you lift.
You can buy a reusable one from Holden or Holden parts dealers. I paid around $50 for mine. It's useful to buy one before you start replacing your plugs as you don’t want to get stuck half way with no gasket.
I got a spare one if anyone would like it too. PM me if you are keen.
platinum, get them from your holden parts place as they are less than $10 each
Well its all done, my mechanic used an aftermarket reusable metal gasket for the intake manifold which should be good if i decide to fit the mace spacers later. Cheers guys.
