Results 1 to 15 of 15
Thread: lowering my vz ute
    vz commodore ute
    Nov 2009
    Default lowering my vz ute
    ganna chuck 20s on.
    wanna put kings super lows in front and super super lows in back.
    camber kit? will i need one?
    how much to do all this? any info would be sweet. cheeers
    Jimmy SV6's Avatar
    Jimmy SV6 is offline Colours Wow, Now It Glows
    [Black] 05 VZ SV6 [Auto]
    Apr 2009
    Hornsby, Sydney
    i know that you can generally get the super lows, and super super lows of ebay and there king springs as well... generally pretty cheap, i aint too sure how much a camber kit would be sorry. i am sure that you could probably ebay that as well.
    vz commodore ute
    Nov 2009
    VY SS UTE
    Jun 2009
    Mandurah, WA
    hey man,
    ive been quoated $900 to install a 4 point k-mac camber kit that costs about $350rrp.
    the only reason its so expensive is cos they have to remove the entire rear k-frame from the car otherwise you can put massive amounts of stress on the axels and other stuff.
    this is what ive been told from west coast wheels which is in mandurah, 80kms south of perth.
    Regards
    George
    2004 XR6T & 1990 VN dragcar project
    Jan 2010
    Bendigo, Victoria
    Mate grab a hold of GSL-Rallysport, one of the site sponsors. They'll be able to tee something up for you
    VZ SV6
    Jul 2008
    any one know how to adjust the cambers on the vz sedans? pretty sure it comes with adjustablility
    vz commodore ute
    Nov 2009
    Quote Originally Posted by W45H1NGT0N View Post
    hey man,
    Regards
    George
    yer my old man told me not to lower my ute because of that. the stress on the axels and stuff. but i knew there was a solution. looks like a camber kit is the way to go.
    ill have motorikes in the back alot so i think a camber kit is a good idea.
    will i be able to have it that lower and big wheels on it without any problems towing the bikes around in the back?
    cheers
    NIXONLS1 is offline Banned
    my mum
    May 2009
    Bansville
    2004 VZ S-Pack Ute
    Jan 2009
    Gladstone QLD
    If your going 20's your gunna have to roll your rear guards or they will scrub like a bitch! Also depending on how low you go on the front you might have to take out the plastic wheel well guards/covers which is quite simple to do. If 20's are not done properly the tire wear will kill your wallet and the ride of the vehicle will be greatly diminished.
    Good look and put up some pics of the rims you are thinking of.
    06vzcalais is offline Donating Member
    Aug 2009
    ive got a camberkit installed in the rear and all bushes throught the car replaced, ive spent alott of money trying to reduce negative camber on my car it will never be corrected and you will always have abnormal tyre wear its just one of the things that comes with lowering an IRS commodore. im actually considering putting it back to stock height
    VZS-Ute06
    Aug 2006
    Western Vic
    I've got super lows all round with NO Camber Kits required
    NO abnormal tyre wear
    VZ-Rob
    98 Ron Powerchip: CAI: SuperLows: GTS Swaybars: Tinted: SS Grille: SS Vents: SS 2:25 Twin Exhaust: ASR Audio:
    vz commodore ute
    Nov 2009
    so how much does it cost to put a camber kit in and all your bushes in?
    will i need to put shorter shocks in or can i just put the springs in?
    Aug 2009
    depends on which shop you go to
    just remember you get what you pay for
    and id put shorter shocks in (putting shorter springs in reduces the travel on the shocks eventually flogging out the longer shock due to reduced travel)
    Aug 2009
    Quote Originally Posted by VZ-Rob View Post
    could be different with the ute as theres a reduced weight over the rear wheels, not to sure ill leave it open for someone to correct me
  15. #15
    vz commodore ute
    Nov 2009
    okay thanks heaps mate.
LinkBacks (?)
  1. lowering front without lowering rear.
    By pillzor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2011, 09:46 PM
  2. Lowering??
    By Ronan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-07-2006, 08:31 PM
  3. Lowering an SV6
    By brownie82 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-06-2006, 04:46 PM
  4. Lowering
    By chopsy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-06-2006, 01:41 PM
  5. need help lowering VS
    By james_and_his_vp in forum V6 Development And Modification
    Last Post: 21-05-2006, 07:00 PM
